2007 with 125k or 2004 with 90k
I'm buying my first GX470 and was wondering which you guys would choose if looks and condition were the same but the years and miles were different as listed above. I've only driven the near Mint 04 and will be seeing and driving the 07 for the first time tomorrow. I'm planning on towing a 6000lb boat and trailer 2x a year and making it a daily driver half the time. Any advice would be great. Thanks
Compare the maintenance histories, but I would lean towards the 2007, because it'll have Bluetooth and variable valve timing.
Chip H.
Chip H.
The 07 may have the timing belt replaced while the 04 is likely required to have one done soon. 07 has upgraded engine with more up. 07 is also newer so ill lean toward the 07 instead.
How bout a 2005 4Runner V8 w 80k
The 2007 was beat on. I found a 2005 4runner that's like new for $7500. Guy needs to sell due to moving.
I'm test driving it tomorrow.
I need it to tow a 5000lbs boat / 1200lb tandem trailer in and out of our slip 2x a year 45 miles each way on flat land.
Any advice would be appreciated, thanks for the help!
test the low range AWD since it is used it or loose it item.
thomasfx10
06-08-20 12:42 PM
werewolf
GX - 1st Gen (2003-2009)
06-25-18 06:02 PM
