Wet Sanding Hazy Headlights
![](https://cimg8.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x1504/63b3101e_0813_4ffc_9331_e4c2a1d9888f_161606c2527b18aedc6e4be7ef1f9d4d6b46c8ea.jpeg)
![](https://cimg6.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x1504/ac70c3ff_b53a_4706_bda5_8faa797f6f46_f8d2e86b7fdc3a97a12ce1ccabd8ee3f20a74dd8.jpeg)
![](https://cimg7.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x1504/50ffd304_1499_4d11_b150_8c5c83582435_8ab04829eaf871e569c1b048339dd145602f8251.jpeg)
Just thought I would share what you can do in an afternoon to some old hazy headlights with some 3000 and 5000 grit wet sanding. I hit them with the orbital and some compound after that.
I’ve used the 3M kit with great success. Takes about 30 minutes for 2 headlights. You can use a drill instead of hand sanding. The key is to seal them up when finished. Otherwise the lights go back to hazy yellow in about 3 months.
This stuff is supposed to work well to seal them and prevent future clouding. I haven't used it myself but plan to one day.
https://www.amazon.com/Spray-High-Gl...dp/B0043B7UQY/
I sprayed some headlights with 2K about 2 years ago they still look the same we'll see how it holds up going forward. The car is always parked outdoors. This is an easier and effective solution
https://www.amazon.com/dp/B01M4RVVX6
