Aftermarket Height Control Sensors
Hi, has anyone installed aftermarket height control sensors for the gx?
There are some being sold for less than $80 a pair while the stock ones run at least $200+ each.
I might be needing to change mine out but debating between converting to a coil spring setup vs replacing both sensors with genuine toyota ones and retaining air suspension. Now if those $80 ebay sensors are viable then it wouldnt be that big of a hit to retain the air suspension.
Thanks in advance for your help!
