low beam and drl are not working
2006 GX470 with electric issue. My wife tells me one of the bulbs are out. When I go out to determine whether Hi or low beam I discover only high beams work. Low beam and DRL to not work at all.
- I read somewhere else that DRL can be deactivated by the Emergency brake being raised. Not the issue.
- I replaced the low beam H11 bulbs still doesn't work.
- I checked the low beam fuses and all are good.
There are also relays involved. Check the under-hood fusebox for them.
Chip H.
Chip H.
Can someone tell me where the DRL 7.5 amp fuse is located? I heard it is not in the main compartment for fuses in the drive side but a smaller one near the battery. I don't see it on the 2006.
You removed the plastic engine bay cover on the driver's side when you were looking?
