Serpentine Belt other than OEM
I was surprised to see the Lexus OEM serpentine belt is selling for around $80 on the internet whereas other brands like continental, dayco and gates are in the $25 to $40 range. Anyone used the aftermarket brands? Looks like the proper part number is 90916-02585
Thanks
Thanks
Have used gates and Continental before, but not on the GX. Although the Gates was used on a Japanese, and Continental on a European. You should be fine.
I believe Mitsoboshi is the OEM supplier to Lexus for the timing belt. You should be able to find it around $40 - $50.
Try searching for this part number: W0133-1613981
No, it was a gatorback belt. Can't find the part number. In addition to the 'v' grooves, it has crosscut grooves which eliminate the squeaking. A picture of the belt pattern is attached. Hope it helps.
Rygar470 (04-07-19)
