Rear spring question
On my FJ I went with a OME (guessing cause I don't remember) HD rear spring and I had it combo's with the stock shocks. I noticed the back was really stiff. I didn't have a tire in rear which may have made cause this, but it was way too stiff in the rear. Does anyone have experience with trying different setups for the rear coil, or can you provide your own experience with what you went with?
I really like like the blistiens and probably going to do the 5100's all round again, however I'm not sure what I should do for the rear spring.
TIA
TIA
Are you looking for stock height or a lift in the rear? Need more info to provide good advice.
Like what IanB2 has said definitely need more information. If you do a rear spring conversion I would do a heavy duty spring since it'll be still. We do those all day here but just put in our toytec superflexes for a nice ride! Let me know if you need help I'm Anthony over at toyteclifts.
Dont mess with any of the HD springs unless you plan on weighing it down with gear....the reason why its stiff was because you didnt have enough weight in the back to soften the ride properly.
I would recommend running either the 2" Radflo rear springs or 2" Icon rear springs. These are your basic rear lift springs that can carry more weight in the rear without being an HD spring.
TIA
TIA
https://www.toyota-4runner.org/4th-g...n-options.html
Check out this thread. It has a a lot of info.
Any advice on front spring rates? I'm looking at Bilstein 6112s which and I've been seeing a lot of conflicting info since it seems that that were designed for the V6 4runner and the V8 is about 200 lbs more. The standard spring rate on the 6112s is 600 lbs but it seems like 650 or 700 lbs would be better for the added weight of the engine. Do you have any experience with these?
captainva (06-27-19)
I forgot I posted this LOL!
Sorry, yes... more info. I do plan on a lift, I'd like to go 3 inches if I can, but will settle for 2 inches if it doesn't mess with the geometry too much. I'm also looking to probably for a 285 or 270/80 size tire.
Thanks for the input so far. Anthony i'll probably be hitting you up soon.
Thanks all!
Thanks all!
fastryan
Suspension and Brakes
06-17-10 10:45 AM
