GX470 features and aux port
Hi,
I am looking to but a 1st Gen GX470 as a daily. I've done tons of research and looking forward to purchasing it.
The only "usability" features my wife and I both need are (1) Bluetooth, (2) backup camera, and an (3) aux port.
From what I can tell, 2007 - 2009 offers all three of these features, but 2004-2006 offers all except the aux port.
I have 2 questions:
1. Is this true?
2. Is there a way to add an Aux port to a stock set up?
I have read that if the GX doesn't have navigation, then an aftermarket radio can be added, but I really need the backup camera.
Thanks for any guidance!
I have 2 questions:
1. Is this true?
Hi,
I have 2 questions:
1. Is this true?
I have 2 questions:
1. Is this true?
Hi,
I have 2 questions:
1. Is this true?
I have 2 questions:
1. Is this true?
Hi,
I have 2 questions:
1. Is this true?
I have 2 questions:
1. Is this true?
Depending on the model GX you get, you might use a different "emulation" mode than SAT, such as DVD or MD. Since I just installed it yesterday, don't know how long it will last, but I placed it in a location that I don't have to remove the radio again, just some trim pieces to change it out. I was using a FM modulator before and it was OK, but I wanted better sound and a cleaner look. Good luck.
baxleyb (06-22-20)
Thank you implantgs4 for the suggestion and experience, This is very helpful. Could you post a picture of how you set it up? How long did the installation take and what tools did you use?
Grom sells a 3.5mm jack interface for only $74 (MSRP)
https://gromaudio.com/store/aux1_ada...tereo-kit.html
If you're willing to spend more (a lot more!) they will soon have a Android Auto + Apple Car Play unit
https://gromaudio.com/store/vline/le...n-upgrade.html
Chip H.
Chip H.
There are several Bluetooth adapters that are out there that might be less expensive, etc, and they all install basically the same way. My problem was that the rear entertainment system was disrupting the installation on the Bluetooth devices that did not allow the choice of different emulations. The other Bluetooth adapters would have worked if I would have left the CD changer disconnected, but the wife would not allow that.
Caffeine27
GX - 1st Gen (2003-2009)
06-04-13 10:35 PM
