LED Bulbs for Switches
Has anyone put LED bulbs in their switches? I have some left over Super Bright LED NEO 3 bulbs I tried to put in to test but the are to big. Anyone have any suggestions?
Then just mic the non-led bulbs and then find white LED's of about same size (eeee-bay or amzon, etc). You'll need a small resistor to knock the voltage down (limit the current), etc.
Since all my switch bulbs are still working in my 2006 GX (less one that was replaced), I have had no motivation to swap to LED.
I do however have motivation to install Phoenix Android unit and replace the ML speakers.
If you have the ML system just be careful with speakers that come with passive x-overs on the speakers. If the OEM speaker has no passive x-over on the speaker, then you need to replace the same way because from info here on CL, the ML amp unit has built-in electronic x-over(s). ML's also use 8ohm drivers, so if you use 4ohm driver you can aid that with a 2ohm power resistor in series, but with better higher sensitive speakers you should not lose any sound output vs the OEM.
