A "quickstrut" is a replacement shock with a spring already installed with a new tophat, ready to swap in without having to disassemble the original and move over the spring and related hardware to the new strut. The front suspension does use a strut, with a shock in the rear.
The problem with quickstruts is they use cheap shocks, and the springrate is not guaranteed to be a match for stock (especially if the application is for a Tacoma), and ride/handling may be affected. You would ALWAYS want to replace in pairs for this reason. As far as physically fitting, yes it should fit, but you will lose the electric adjustable function of the stock suspension obviously.
