Street Rays Lift Spacers
I'm looking to put a 1.5" spacer left on the front of my 08 GX470 but am having a hard time finding spacer that list the GX as a fitment. Does anyone know for sure if the ones made by Streetrays for the 03-18 4 Runner will work? I've seen posts from people that have used some from Streetrays but they didn't say which ones. Thanks in advance for the help. These are the ones I'm looking at https://www.streetrays.com/streetray...er-tacoma.html
The e-adjustable shocks is one other key difference between the GX470's and the 4th gen 4Runners, and may come into play with a front spacer lift, especially if it installs on top of the tophat of the strut assembly, rather than on top of the spring within the assembly. I can see the solenoid not engaging to the adjuster on top of the strut properly/at all if you add a spacer between the top hat and the strut mount, as the solenoid is on top of the strut mount. It's been a few years since I've had that system on my truck though, and I can't remember exactly how it all goes together.
IanB2 (01-13-22)
I'll be the guy to say it...the ride quality with a spacer lift is going to suck compared to using a lift spring. Since you'll need an alignment after installing the spacer, you should seriously consider just using a spring that will achieve your goal instead of a spacer.
It's a bit more $$ up front, but you'll be happy you spent it the entire time you're driving around lifted.
I've seen a lot of mixed reviews about ride quality, and I know it can be pretty subjective. Most seem to agree that the pre-load type spacers are far worse than the type that sits on top of the mount. Most also say it improves when a taller tire is installed, which I plan on doing.
