Misfire mystery
3rd Gear
So what a weekend I had,
Here's what I have. 216000 miles on a 2004 GX470 I picked up a few months back that was neglected. Original plugs and coils and recently started throwing a P0355 code. I knew the plugs were toast so I put in new NGK IR plugs and the code remained and now idled rough. I swapped coil packs 1 and 5 and now had a P0351 code, so ok I need a new coil pack. Installed the new Denso OEM coil pack on cyl 1 and back to P0355. Swapped the new coil pack back to 5 and still misfire on 5. I checked the plug and swapped it thinking it could be bad as well but no matter what I do I still show a miss on 5.
After this game of ignition musical chairs I checked the connector and wires to it and they appear to be great so my frustration continues. I took a borescope to make sure there wasn't any burrs grounding out my plug and it looks great.
So what's left? I am going to cut back the wire loom and expose the wires to that coil and see what's what. Would the injector throw a separate code? Perhaps that's bad or clogged? Perhaps a bad headgasket or bent valve causing low compression?
The confusing part is my initial diagnosis when I swapped coil packs 1 and 5 and had a P0351 code that I cannot replicate.
Any help would be appreciated. I am new to the 2UZ but not new to cars. Just wondering if there are any other bugs that may cause this?
Thanks
Thanks
I'd do a compression test at this point to rule out mechanical issues with cylinder 5.
1. Double-check that the connector seated all the way on #5. And that it "clicked" solidly.
2. I would also follow the wire bundle back, feeling for any rough spots, in case an animal chewed on it.
3. Reset the computer by disconnecting the negative battery terminal for 1-2 minutes. When reconnecting, try for minimal sparks (be fast and accurate with the terminal).
4. Swap a different coil pack (not the new one, not the original) and see if the code clears)
Chip H.
Chip H.
Bummer. Glad you found it.
Chip H.
Chip H.
Was the harness damaged? Sounds like a real PITA to track down, good job!
turtlepeas
04-19-20 10:26 PM
