Brake Recommendations
Old 03-01-23, 07:47 PM
Shantheman
Shantheman's Avatar
Is this for the upgrade to gx460 parts or is this just new gx470 parts?
Originally Posted by offroad200
I went with Power Stop Z36 pads and they were a huge improvement in brake feel over stock. If you are replacing calipers and rotors anyways, why not get the whole Power Stop kit?
Basic replacement:
https://www.rockauto.com/en/moreinfo...4204&jsn=10973
Fancy replacement with Z36 pads:
https://www.rockauto.com/en/moreinfo...4204&jsn=10980
Old 03-02-23, 06:27 AM
offroad200
offroad200's Avatar
This is the upgrade to GX460 parts.
Shantheman (03-02-23)
Old 03-02-23, 01:41 PM
NTH
NTH's Avatar
I second the Powerstop Z36 kit. Very noticeable braking power!
Old 06-24-23, 11:51 AM
BOFF
BOFF's Avatar
Replaced the front brakes today as the wife's vehicle had some front shaking during braking.
Upgraded to the GX460 front calipers and rotors, and used the Power Stop kit KC5873-23. Only difference between it and the -36 kit was the pads and price.
Fairly easy and quick to do.
I opted to not use/add stainless brake lines as it's the wife's daily road/driver, and the current ones were ok.
So, to save time and fluid, I just hung the stock calipers to the side with wire.
In order to do so, I took the metal plated holding the metal line to the rubber and unbolted the bracket that they went through.
Cleaned the new rotor with brake clean, and put the new rotor on after using wire brush to clean the mounting surface and and snugged it with the lug nuts.
Bolted the new caliper in place, and then unscrewed the metal brake line from the old caliper and quickly screwed in the brake line to the new caliper.
I then re placed the metal holing plate first, before bolting the bracket back in place.
Put in the pads, anti rattle clips, pins, and pin clips.
Rechecked the all the bolts and torqued to specs, added Dot 3 Brake fluid to the brake reservoir, then added a clear hose to the bleeder valve to see when bubbles are gone, and bled the brakes. Add more fluid to the brake reservoir when finished.
Keys point- I didn't check the dust shields and had to remove the front tires once everything was installed to pull the dust shields away from the rotors, as they were rubbing and making a terrible noise.
There is a recommended break in technique for the brakes on Power Stop Brakes webpage, and I have always followed that for Power Stop Rotors/Brakes.
God Bless,
David B.
JTiger2010 (02-20-24)
Old 07-15-23, 12:45 AM
muldowney2
10th Gear
muldowney2's Avatar
How would one find the part numbers to replace 2007 gx470 brakes with gx460 parts?
Old 07-15-23, 02:33 AM
ALAN553
ALAN553's Avatar
Just look up the parts for a 2010 GX 460
Old 07-15-23, 09:04 PM
muldowney2
10th Gear
muldowney2's Avatar
Default 479 to n460
I wonder why they dropped the 470 and started the 460?
Old 07-16-23, 02:33 AM
ALAN553
ALAN553's Avatar
they changed the engine to a 4.6 L?
Old 07-29-23, 10:26 AM
muldowney2
10th Gear
muldowney2's Avatar
Beautifully done video. Taking your advice re conversion to the 2010 4runner OEM Toyota parts (same part numbers as Lexus). Do you use the torque specs (123 Nm) from the 2007 GX470 for the new calipers bolts?
Thanks very much.
Old 07-29-23, 10:47 AM
muldowney2
10th Gear
muldowney2's Avatar
Not sure the wife would appreciate your statement about keeping the old brake lines!
Old 07-30-23, 05:27 AM
chiph9
chiph9's Avatar
Probably emissions and mpg laws.
Agree on changing the brake lines. I had mine done last year and they were fairly firm, heading for "hard and crunchy"
Chip H.
Old 08-02-23, 02:35 PM
Lexus4321
Lexus4321's Avatar
The GX460 upgrade makes sense. I had recently put back on my EBC slotted/dimpled rotors with new Wagner ceramic pads. The pads are interesting, the friction is mounted to aluminum backer, not steel.
So far the EBC/Wagner set is holding up ok.
Old 08-04-23, 09:01 AM
kamlung
kamlung's Avatar
Originally Posted by NTH
Can you tell me where you got those replacement plastic shields with the AP sticker on them? mine are all ripped and cracked but OEM prices are a bit crackhead...
Old 08-04-23, 10:33 AM
Davenlei
Davenlei's Avatar
They are available on eBay. There are several resellers and they are cheap.
Old 08-05-23, 04:43 AM
muldowney2
10th Gear
muldowney2's Avatar
did the upgrade to the 460 pads, rotors, and calipers -
drives like a dream
Quick Reply: Brake Recommendations
