Problems with fuse controlling reversing light, turn signals, and airbags
3rd Gear
Buen día hace 3 días mi Lexus GX2005 470 se está rompiendo el fusible que controla las señales de giro, la luz de reversa y las bolsas de aire. Mi problema es que cuando pongo la marcha atrás dura unos 5 segundos y se rompe el fusible, quito las bombillas y todo lo del revés por si me quedaba corto, pero este todavía tiene 10 fusibles rotos
3rd Gear
Good day 3 days ago my 2005 Lexus GX470 is breaking the fuse that controls turn signals, reverse light and airbags. My problem is when I put the gear in reverse it lasts about 5 seconds and the fuse breaks, I remove the bulbs and everything from the reverse in case I was short, but this one still has 10 broken fuses
I don't really see a connection between all those.
But try putting the mirror select switch (L - R) into the center position so the outside mirrors don't go down when you put it into Reverse.
Chip H.
Chip H.
Jpivnik
RX - 3rd Gen (2010-2015)
09-20-20 09:35 PM
