Kdss
![Cool](https://www.clublexus.com/forums/images/icons/icon6.gif)
I have an '04 GX with KDSS on order. My salesman said the vehicle should be in within the next two weeks. My question is, if anyone knows, will KDSS be a solution for the vibration problem?
KDSS is a handling option and does not cure the vibration problem.
http://us.lexusownersclub.com/forums...T&f=28&t=5042&
![Thumbs up](https://www.clublexus.com/forums/images/icons/icon14.gif)
I just picked up my new 2004 Dorado Gold GX with KDSS about a week ago. I have logged about 300 miles so far. I believe the KDSS GX rides much nicer than the GX I test drove without it. I know its subjective, but the ride feels more controlled and less floaty in the "comfort/normal" setting than the tester did, without any compromise in ride quality. As far as leaning less when cornering, it helps in that area also. I didn't do a lot of fast cornering in my test drives, so it is hard for me to compare it to the GX without the KDSS. But, my last vehicle was a 2001 LX470, and I can say that this GX with the KDSS corners much better than the LX and the GX is a narrower and taller vehicle.
Hope this helps.
Hope this helps.
![Smile](https://www.clublexus.com/forums/images/icons/icon7.gif)
Also forgot to mention.........
I have not experienced any vibration problems or feelings like I have been rear-ended when I come to a stop as I have read on other posts/forums. Also, it appears Lexus fixed the temp guage as it is close to accurate as far as I can tell.
frank69m
GX - 2nd Gen (2010-2023)
14
03-19-13 11:29 AM
