Just got my Xenondepot H11 kit!!
Old 02-19-12, 07:26 AM
  #136
chrisvr6
chrisvr6's Avatar
Originally Posted by Booyah
If your kit is same as mine then you have a fuse for each light---open up that fuse holder and look at it, mine got all corroded and I had to pull the fuse out and clean it up in there and replaced with new fuse--mine woulnt fire up either on one side and thats what I found to be the problem
fuse in hid relay box? i dont think mine opens up? besides, its brand new!!
Old 02-19-12, 07:29 AM
  #137
chrisvr6
chrisvr6's Avatar
Originally Posted by redrocks
Are you still using "Auto" light setting?
sparatic firing in auto. have to switch off then to manual setting then i can go to auto. this volt kit is garbage. cant believe i spent $100 on it. going back to hidextra. fml.
Old 02-19-12, 10:45 AM
  #138
Booyah
Booyah's Avatar
The fuse Im taking about is the one right in line before you hook it up to the pos batt terminal. I have the Extreme HID kit.
Old 02-20-12, 05:16 AM
  #139
chrisvr6
chrisvr6's Avatar
the volt kit has nothing to hook to battery.
Old 02-20-12, 05:19 AM
  #140
chrisvr6
chrisvr6's Avatar
i noticed i forgot to turn lights back to auto after all this and left them in on instead. they did still turn off automatically though. i wonder how long they were on before they turned off?!
Old 02-20-12, 10:24 AM
  #141
cdew002
cdew002's Avatar
They will turn off after a few minutes.
Old 09-11-17, 11:27 AM
  #142
hitsofmiss
hitsofmiss's Avatar
My driver side lamp went off. Thinking of upgrading to HID.
Based on the consensus here, the "H11 HID Kit - Xtreme" with Philips 4300K from XenonDepot seems the defacto standard.
1.) Does anyone have the latest CL coupon?
2.) Will the kit contain both High & Low beam?
The fog lights are working fine. I guess, I can hold-off on those for now.
I'm also thinking of replacing the housing since it has become extremely hazy ('07 GX) . A few threads recommends OEM whereas others recommend a Projector housing.
3.) Can anyone please recommend a specific brand/ model?
Thank you!
Old 09-12-17, 06:44 AM
  #143
XenonDepot
Former Sponsor
XenonDepot's Avatar
Thank you!
1- Unfortunately, there are no active forum coupon codes at this time. Having said that, we are offering an extra 10% off any order or 20% off orders over $200 right now.
2- No, as the GX uses separate bulbs for the low and high beams so you would need to get 2 HID kits. I would recommend going with LED for the high beams as they would function better since they are instant on but they won't be as bright as the HID kits.
3- A great cost effective way is to clean your headlights with a headlight cleaning kit. If that does not work or last then you can look into getting a new headlight, I believe the GX has factory projector halogen headlights which still makes it a good candidate for the HID kit upgrade.
Danny
Old 10-15-17, 11:57 PM
  #144
hitsofmiss
hitsofmiss's Avatar
Danny
Thanks Danny! I ordered the Xtreme Kit with 4300k Philips bulbs. However, nowhere on the bulb or package it says Philips, 4300k or Made in Germany. Am I missing something?
Old 10-16-17, 07:04 AM
  #145
XenonDepot
Former Sponsor
XenonDepot's Avatar
@hitsofmiss -
Philips does not directly make an HID bulb that you could connect to a Halogen base fitment. The Philips D2S HID capsules you received have been removed from their original bases and attached to a custom-moulded H11 halogen base. The markings that identify that capsule as a Philips product are on the original Philips d32 bases, and since the base we provide is not a "Philips" base, we cannot lawfully stamp ‘Philips’ on it.
Hope this helps,
Steve
Old 11-04-17, 12:30 PM
  #146
hitsofmiss
hitsofmiss's Avatar
I'm not very handy with cars & I'm finding the installation a bit overwhelming. I could not find any installation videos for Lexus GX 470 online. I spoke with Danny who confirmed that & asked me to use other cars video as a reference. I found this thread but some of the pics are not very clear. Most likely it is me since I have never done it before & I don't know where & what to look for some of the parts in the instructions. A Video would have been nice.
So, I spoke with 2 mechanics who does most of my work & are very reliable. One of them is a Lexus specialist. Both advised me against installing the kit. The first said, the housing gets too hot & will eventually burn it. The other (Lexus specialist) said, he gets more people coming to him for uninstalling the kit because the bulb blow quite a lot & for other reasons. And another issue is aligning it. In some of the states, it is illegal.
I'm a bit confused. I want better headlights but don't want to incur additional expenses down the line. Has anyone experienced any issues with the Extreme HID Kit post installation or has found any helpful videos?
Thank you!
Old 11-05-17, 11:55 AM
  #147
caha14
caha14's Avatar
Thank you!
I can understand why you might be torn, as I went through the same thought process many years ago. Ultimately, I purchased two kits over the years. One lived in my GX 470 for 1.5 years. The other went on the LX 570 and was on for 6.5 years. Both were completely trouble-free.
On the installation front, unfortunately, it is what it is, though it truly isn't as bad as it might seem, especially on the GX 470 (LX was harder). In general, on both vehicles, it did take me longer than average to install, but that's because I am a bit retentive about things looking factory AND not drilling into the vehicle to attach components.
As for the other concerns, with all due respect to your two technicians, that is all a bunch of hearsay. While there is a lot of conflicting information out there, most numbers I've seen confirm that the xenon bulbs run cooler than the factory halogen bulbs. And well, the housings in both my GX and LX (with AFS, to boot) were intact upon uninstalling the kits.
In terms of burning out, that may be true for crappy kits, but it was simply not my experience with XenonDepot kits.
Old 11-06-17, 05:49 AM
  #148
XenonDepot
Former Sponsor
XenonDepot's Avatar
Thank you!
It was nice talking to you on the phone the other day. I wasn't able to find a video HID install guide for your GX470 but here is one on how to get to your headlights to change the bulbs: youtu.be/7V8Z2vqVA6w
As to how to install the kit in a vehicle, here are a few from other vehicles that should help further guide you: http://www.xenondepot.com/Reviews-s/60.htm
Concerning what the two mechanics said, the HID kits would actually run cooler as they are a lower wattage setup 35w vs 55w from the halogen bulbs. I could understand people having issues with a lesser quality HID kit as we hear that a lot from customers but we ensure we sell quality HID kit that is easy to install and functions without any issues.
Danny
Old 11-13-17, 04:24 AM
  #149
NTH
NTH's Avatar
Danny- I bought your Extreme Kit with 4300k bulbs a few years ago and it has performed perfectly. Recently I noticed the color has gotten warmer and not as cool/white. Is this normal after a few years of use?
Old 11-13-17, 05:50 AM
  #150
XenonDepot
Former Sponsor
XenonDepot's Avatar
Yes, that is perfectly normal. As like any other bulb, HID bulbs can dim and change color over time. Sounds like its just time for some new HID bulbs!
Danny
Quick Reply: Just got my Xenondepot H11 kit!!
