GX470 H11 Xenondepot kit installed DIY guide
#49
![Talking](https://www.clublexus.com/forums/images/icons/icon10.gif)
The store is in Flushing, New York , Just a retail. I don't think they ship outside than NY.
But I think you can search for "RAZO" that's the company name.
This is really good! Use less power! compared with the OEM 65W, this one uses only 55W.
I do think the have H3 (our fog light!) and same white color!
#50
Hey Tony,
Do you really have to take out the battery when installing the H11 kit?
'Cause I read that you needed to take it out.
And I'm worrying about that the windows can't not open after putting the HID.
David
David
#51
hi Adil,
The bulb is just like the OEM one, unlike the HID.
and it's so simple to put it in!
But HID produces brighter color and needs little power (35W)
David
David
#52
Originally posted by DavidsGX
Hey Tony,
David
Hey Tony,
David
#54
Dave
It is impossible to access the shelf below the headlights without removing the battery. Trust me, to run the wires through the front fire wall you will also need to remove the battery. There is simply no other place to put the ballast inside the engine compartment on the driver side unless you remove the battery.
Resetting the windows only takes 40 seconds now that I know how to do it. I posted the exact procedure on how to do it, so dont sweat it. If you really want a clean install remove the battery unless you like having bloody knuckles and special tools. Also the relay and negative screws are right next to the battery and you can't access them without removing the battery. Instructions for resetting the windows are on page 3 of this thread at the very bottom.
If you use the same ballast anchoring locations on my instructions you should install this kit in 45 minutes or less. All my friends can't believe how clean and factory everything looks if you did not know any better you would not even know the HIDs did not come out of the factory.
#57
Just ordered the 6,000K H11 Kit tonight from XenonDepot using the group buy discount. How long did most of you wait to get it?
Thanks for all of the great info.
'02 RX300
'04 GX470
'02 RX300
'04 GX470
#58
You should e-mail Steve from Xenondepot and ask him how long your kit will take especially if he is running low on stock. When I ordered mine he had only a few left in stock because we are competing against the Acuramdx.org guys who also have H11 lights. Steve from xenondepot is very honest and will give you a correct time for shipping and other info. I know he has lots of 4300k kits but he is running low on 6000k kits.
I live in Las Vegas and he had my kit shipped to me in one week from Canada. He uses DHL and will give you a tracking number when you order the kit.
#59
![Wiggle](https://www.clublexus.com/forums/images/smilies/wiggle.gif)
![Dance 1](https://www.clublexus.com/forums/images/smilies/dance1.gif)
#60
I ordered the 6000K HID kit two days ago and I was told they're out of stock so I will have to wait. Hopefully they will inventory their 6K products soon so they can ship out to us.
