DIY- GX illuminated door sills- 56k will self destruct!!!
Old 03-22-07, 10:06 PM
GS3Tek
GS3Tek's Avatar
Cool DIY- GX illuminated door sills- 56k will self destruct!!!
Well, I finally finished putting this together. Here it is Capirato
This is basically a transplant of the SC430 illuminated door sill into the GX. It was too big to fit into my GS door sill.
Disclaimer:
I'm not responsible for any damage or accidental amputatation
I apologize for the poor engrish, grammer, punctuations:smile:
*illum=illuminated
1. oem SC430 door sill
2.
will be removed with box cutter. metal sill is held with very sticky black adhesive
sill is clipped onto black tab. push it up on both sides w/ flathead screwdriver so the boxcutter can remove the sill
continue sliding the cutter with firm pressure
illuminated piece off, held w/ double sided tape
slide the cutter only at edge. don't worry about the scratch b/c it will be covered by the metal sill
Old 03-22-07, 10:07 PM
GS3Tek
GS3Tek's Avatar
Thumbs up
9.illuminated pc removed, top view
10.close up view of led on each end
11.
12.GX sill. that logo will be removed by sliding the cutter underneath. it was already removed so I was holding it there with my hand.
13.Top:logo removed and shaved. Middle: finished sill Bottom: illum logo
14.push up the plastic tab where the metal sill is clipped into so the box cutter can slide under the metal sill for removal
15.
16.metal sill removed.notice the black adhesive.top shows the door sill measured and cut out for the illum logo to sit in
Old 03-22-07, 10:09 PM
GS3Tek
GS3Tek's Avatar
Thumbs up
17.after removing the Lexus logo, time to cut the metal insert where the
illuminated logo will show through.
18.Red: already cut by the factory, it's not attached. Green: needs to be cut.Cut right in the center
19.Each side is bent back. Gently bend it back and forth and it will snap/break off.
20.Inside metal is broken, but the edge is jagged and not clean
21.shave/sand it down. I used a metal carbide to grind it down.
22.Nice and clean
23.ready for the illum logo to show through
24.plastic sill is cut with the box cutter for the illum logo to sit in
25.illum logo sits b/t exactly between both plastic tabs (left tab shown with my finger-right tab shown with the screwdriver head) that snaps on the car
Old 03-22-07, 10:10 PM
GS3Tek
GS3Tek's Avatar
26.nice and perfect fit, lit up too. metal sill is not attached yet.
27.
Voila! End product. Not wired up to the car yet, but will run the wires from the running board to the illuminated sills. It will light up whenever the door is open like the running boards.
Old 03-22-07, 10:22 PM
ARISTOh
ARISTOh's Avatar
Very nice write up... wish you could have done it for the GS....
Old 03-23-07, 05:40 AM
The G Man
The G Man's Avatar
Looking good, how long did it take you to do it?
Old 03-23-07, 09:17 AM
DavidsGX
DavidsGX's Avatar
Nice mod! Was it expensive to get?
Old 03-23-07, 02:10 PM
GS3Tek
GS3Tek's Avatar
Thank you for the compliments
Both oem sc430 door sills were $80.
My first one took 2 hours b/c I took my time. 2nd one took about 1 hour. The long part was shaving down the metal clips at the edge.
I know that this a bummer b/c the catch was to buy an SC430 door sills .
There's hope:
Here's what you can do if you can't find any lexus illuminated sills.
(If I have the time, I will try to do the rears from scratch.)
This is what I plan to do to fabricate a new illuminated logo piece:
Follow steps 12-23, then proceed to these steps:
Attached Thumbnails DIY- GX illuminated door sills- 56k will self destruct!!!-lexus-logo.jpg
Old 03-24-07, 05:05 PM
Pearlpower
Pearlpower's Avatar
Very nice writeup.
Old 03-31-07, 03:11 PM
GRAND_LS 4
3UZ-FEEEE
GRAND_LS 4's Avatar
Thanks for the write up... two for DIY posters.
Old 04-03-07, 10:45 AM
The G Man
The G Man's Avatar
You should sell them on ebay.
Old 04-04-07, 11:04 PM
GS3Tek
GS3Tek's Avatar
Thanks for the compliments everyone.
My gx is a lease, so I'll change them out when the lease is up.
Here are updated pictures, but only the driver side so far. Haven't wired the other side.
up close
Old 04-10-07, 10:43 PM
pump142
pump142's Avatar
I agree, Id buy a set in a heartbeat.
How was wiring them in?
Old 04-10-07, 10:51 PM
GS3Tek
GS3Tek's Avatar
When my lease is up, expect to find them here
Wiring was pretty easy...just have to get under the gx.
I spliced into the front running board lights, then through the inside. If you crawl under, you'll see rubber grommets that lead into where the door sills are snap onto.
I'll try to get pictures when I do the other side.
Old 04-11-07, 09:32 PM
pump142
pump142's Avatar
You know you want to make some more <using jedi mind trick>
Quick Reply: DIY- GX illuminated door sills- 56k will self destruct!!!
