Removing Roof Cross Bars
Does anyone know how to remove the black cross bars? There is too much wind noise and I will never use them. Plus I am sure they don't help gas mileage.
Nooo you don't. Just remove the rear cap as noted in the pic, and slide the crossbars out of the rear of the slots after loosening the sidebar adjustment nuts. I've done it. Really simple mod.
I just took mine off, but haven't been on the road to check on the windnoise.
I took mine off by just sliding back the rear plastic covers and then squeezing the rails by the covers.
It seems that the covers are easily broken if you were to remove them.
I also only moved the rear covers and took both rails off that way
I dont think not much of a difference, I have had it on and off couple of time, the cross bars if you notice are aerodynamiclly shaped ( aircraft wing ) , so that they can have the wind deflected at minimum resistance. The noise is higher when you have cross winds than head wind.
stiles_s
GX - 1st Gen (2004-2009)
03-25-07 07:59 AM
