Speedometer not working...
I had the battery on my GX470 (2004) changed.
Now, the speedometer is not working. The odometer works. The RPM needle works. The hot/cold gauge works. The fuel gauge works. Everything else in the car works.
The speedometer needle does not move. At times, it seems a little jumpy. But, it does not move off of zero MPH.
I disconnected and reconnected the battery again. But, nothing changed. One time when I started the car, the RPM needle did not move up. Then, it jumped up all of a sudden.
I called two Lexus service centers and neither one had a clue. They both said, "bring it in." I thought it might just be a fuse. But, I cannot figure out which fuse it would be. None of the ones under the dash nor under the hood say anything about 'speedometer'.
Any ideas/suggestions?
Thanks.
Thanks.
Yesterday, the Speedometer worked for a 25 mile trip across town. Then, on the way back, it didn't work. Same thing happened today.
Kind of scary if even Lexus doesn't have a clue.
The cost of repair was $787 for the part and another $110 for labor. It takes a few days to get the part in. Not something they have at the shop. Also, they need to program your mileage into the new meter.
My GX470 (2004) now has this problem - can you tell me more about this ? I went to the website you recommended here - but it shows something else.
Anyone has recommendation of where the repair ? Like previous post, the dealer wants $1300 to replace the instrument cluster. That kinda steep...
SuicidnS13
07-31-12 11:20 AM
mr29rose
SC- 1st Gen (1992-2000)
06-19-10 05:57 PM
