Loud clicking when GX starts
We bought a 2006 GX back in the fall. For several months now, when first starting the car, it makes a loud, rapid clicking noise for 10-25 seconds. It seems to originate from the front left side of the car. I don't believe it's the uphill or downhill assist control, as the clicking occurs whether the car is in park, reverse, or drive. It only seems to happen when the car hasn't been driven for several hours. Is this normal? Any thoughts?
If it's a ticking sound that's audible upon warmup when the engine is cold and disappears after it warms up, it could be a cracked exhaust manifold. The 2UZ V8 on the landcruiser/LX470 is notorious for this; not sure if the GX has the same problem.
My 2005 GX also makes a similar clicking sound from somewhere up front. It only happens when I start up a cold engine, put it in reverse and back out of the garage. It goes away in about 5 seconds. I keep forgetting to tell my dealer about it.
I know this is an old thread but wanted to see if anyone has an idea on the cause of this clicking sound. My 07 with about 83k on the clock I started having this issue a few months ago and it seems to be getting worse and lasting longer. Only happens when its been sitting for a few hours or over night. Seems to be coming from the front left of the engine compartment.
Thanks for any suggestions.
Starter? As a starter begins to wear out sometimes the contacts will stick causing the multiple loud clicks. I have had this happen exactly once. Sticking starters are a time bomb, because once the contacts fully wear out they will stick together completely, pulling massive draw from the battery, which almost always causes a fire. Cool, huh?
This may not be your issue, and the starter is located between the two cylinder banks.
Well that doesn't sound very fun at all. I wouldn't say this clicking is loud but certainly noticeable. Not like the clicking you would here if the battery was almost dead and trying to turn the starter. It's a fast clicking sound. Started out lasting a few seconds but now going on for about a minute or so. When I stuck my head in there this weekend it seemed to come from the front right - passenger side - near what i think is the alternator. I changed that out about 8 months ago. Is the starter located on that side of the engine?
If it's the starter you would also notice problems with the engine firing up, or running smoothly.
Again- it's probably something else. Starters don't fail too often.
I haven't torn into the 2UZ (motor of the GX), but all the diagrams I've seen show the starter sitting between the two cylinder banks- the middle of the top of the engine.
I can tell you all about the 1FZ motors of the earlier landcruisers, but I'm new to these as well.
