How to access reverse lights bulb?
Old 12-11-08, 10:42 AM
bobinsofla
bobinsofla's Avatar
Default How to access reverse lights bulb?
I've searched the archives (both GX470 forum and lighting forum) trying to find how to access the bulbs on our reverse lights that flank the license plate, but found nothing.
Has anyone replaced the reverse bulbs, and if so do you have to remove the interior trim panel on the taligate to get at them, or can the light lenses be removed from the exterior? I did not see any screws or bolts that were around the lense assembly....
Thanks,
"Blind in the dark" Bob
Old 12-11-08, 11:22 AM
STDave
STDave's Avatar
https://www.clublexus.com/forums/gx-...ate-light.html
Give this a try. I think this is the right approach.
David
Old 12-11-08, 11:37 AM
bobinsofla
bobinsofla's Avatar
Thanks. If I read the thread correctly you can pop the lense assembly out from the outside????
David
Old 12-11-08, 03:52 PM
Wronglane
Wronglane's Avatar
Hmmmm,I await a reply to this also. My orde from V-Leds came in today.
Old 12-15-08, 12:14 PM
bobinsofla
bobinsofla's Avatar
Default Talked to Lexus Master Tech
Bulbs are only accessible from inside - meaning you need to remove the interior trim panel on the rear door to replace them.
If someone has been able to do it from the outside I sure would like to have them describe exactly how it was accomplished.
Old 12-15-08, 01:15 PM
Wronglane
Wronglane's Avatar
Bob,did you install your yet? If so,how ?
Old 12-15-08, 04:24 PM
cmarshack
cmarshack's Avatar
Here you go...
Old 12-16-08, 11:43 AM
bobinsofla
bobinsofla's Avatar
Thanks...I think.
What the hell is a Garnish? I mean I know what the word means, but in this context is it referring to the outside chrome trim piece above the license plate?
Old 12-16-08, 12:04 PM
bobinsofla
bobinsofla's Avatar
In the link in the first reply to my post, there are two members who claim that you can remove the light housing from outside. but I still can't see how to do this (easily).
Originally Posted by cmarshack
Here you go...
Old 12-18-08, 08:17 AM
cmarshack
cmarshack's Avatar
If you look at this last picture you can see the two "claws" that hold the lens in place...I am asssuming that you can carefully pry this out from the outside (insert disclaimer: If you brake yours don't come asking for me to help you replace it...do it at your own risk).
Old 12-19-08, 09:59 AM
bobinsofla
bobinsofla's Avatar
I think I'll do it the long (right) way. I just don't see an easy way to do it from the outside without, breaking, scratching, or screwing something up....
Old 12-19-08, 11:51 AM
cmarshack
cmarshack's Avatar
Probably a good idea
400fan
Lighting
06-05-19 11:32 AM
LexSCthree
11-11-10 04:40 AM
pizdets17
10-16-09 10:40 AM
bobinsofla
Lighting
12-15-08 02:38 PM
YuuDawg
SC- 1st Gen (1992-2000)
10-11-01 07:29 PM
Quick Reply: How to access reverse lights bulb?
