Vibration and Noise With One Window Down
Old 12-29-08, 01:10 PM
bellaGX
bellaGX's Avatar
Question Vibration and Noise With One Window Down
I have a 2005 GX470 and whenever I have one window down only, the sunroof vibrates and it sounds like a helicopter is landing on top of my car. Is this simply because the car is so airtight? When I roll down additional windows, it helps. Is this normal? THX
Old 12-29-08, 01:13 PM
The G Man
The G Man's Avatar
The Helicopter noise is cause by the Bernoulli principle. It is pretty common in newer, more areodynamic cars.
A car at speed will cause an air stream, more so at the side rear window. That air stream creates a low pressure zone where it will draw the air from inside the car to the outside air stream. As more and more air is being drawn out, at some point the air pressure inside the car actually becomes lower than the outside air pressure and a rush of air enters the car. This cycle repeats itself and the air moving in and out of the car is what cause the helicopter noise that you hear.
Old 12-30-08, 06:44 AM
itsZep
itsZep's Avatar
i was surprised the first time it happened to me too....but it only happens to me when I have the back windows open only.....if it starts happening...crack your front windows a bit and it should dramatically reduce the effect....
Old 12-30-08, 06:50 AM
Ice350
Ice350's Avatar
Yeah, that crap trips me out. Last weekend I did it on purpose thinking it will go away if I kept that rear window down. It didn't and aggravated the heck out of me. I then realized I was dealing with physics and science so I let it go.
Old 01-08-09, 01:41 PM
tgergen
tgergen's Avatar
+1 Just crack another window and it will go away.
Old 04-11-24, 12:58 AM
swhittington670
1st Gear
swhittington670's Avatar
Default Helicopter wind noise/vibration.
Ok, that's good to know. However, how do you resolve the noise/vibration?? Do aftermarket window deflectors resolve the issue?
Old 04-11-24, 06:15 AM
IanB2
IanB2's Avatar
They definitely help, but I'm so used to cracking a 2nd window that I've never tried just one window down since getting the visors, lol.
GKLCPA
14
01-14-20 09:57 AM
RshaoKh
RC F (2015-present)
10-15-18 11:13 AM
RealMarty
08-19-11 02:23 PM
Ochasey
ES - 5th Gen (2007-2012)
09-21-10 06:10 AM
HarrierAWD
RX - 1st Gen (1999-2003)
05-14-04 08:20 PM
Quick Reply: Vibration and Noise With One Window Down
