Reasonable Cost for Brake Service on 2002 GX470
Dealer quote seems quite high. What's a reasonable charge for brake service on a GX470?
Not sure if he was quoting for all 4 discs and rotors, or just discs.
All 4 pad and new rotor from the dealer should cost about $1200 to install. You can buy the oem parts online and use a local machanic to install and save a few hundred.
Lexus turned my front rotors for $360, I bought after market pads for $69 a set had them installed by another mechanic for $110 labor for all 4. So pads all around, turned front rotors all for $608. I could have saved a $100 and had Toyota turn my rotors but my SA has been good to me so wanted to throw him a bone.
Lexus quoted me approx $700+ per axle for just new rotors (parts/labor).
Another avenue to try is going to a Toyota dealership and have them do it. Toyota quoted me $575 per axle for rotors only.
I found brand new OEM Front Rotors online for $102 each. OEM Rears are $96 each. OEM front pads are $48 and the rears are $42. So parts all around are about $500...
ZZZDoc, How many miles have you gotten out of your brakes?
Warped rotors need not be replaced, get it skimmed, then you get pads of various choice, I had earlier around for 3years with Akebono Ceramic Brake pads cost per pair paid 70/-$ These were too good. This cost is for skimming the rotors another 280/-. And if you have the tools the job should not take more than 2 hours from the time you have the skimmed rotors . Total job from removal to fitment should not exceed 5 hours. you save on the labour.
Contact these people to see what they would charge you for pads and rotors.
http://www.autopartintl.com/company.htm
I don't know if they will add shipping for Alaska, But we have a warehouse right down the street here in Maine. I call, ask for a part. and I have it either in 30 minutes, or 24 hours, depending on if it is in the local warehouse, or in another state. Their prices are better than anywhere else I have contacted, and the service can't be beat. Haven't used them for Lexus Parts yet, as I am driving a CPO vehicle under warranty, but I have used them for several other cars I have owned with nothing but rave reviews.
![Smile](https://www.clublexus.com/forums/images/icons/icon7.gif)
http://www.parts.com
This is where I pulled all the pricing from on my earlier post... If you enter yr/make/model then use the search function to the right and type in "rotor" or "pad" everything will come up.
I can mail it you the DIY for Brake pad change. if interested send me your email address. This is DIY done at home garage, with all tools available, and some borrowed from my friends.
stevelifts
05-25-22 08:25 AM
