Last edit by: IB Advertising
Browse all: General Overview
- Warning Lights
Important information to help you understand your Lexus
GX 470 Warning Lights VSC OFF, VSC TRAC, Anti Skid, Check Engine
#121
Thanks all for this thread! I bought a "new" 2005 GX470, and the VSC OFF/VSC TRACK/CEL just came on today after a week of ownership. I drove to the Toyota dealership, bought a new gas cap (part number: 77300-47010), drove four miles to an AdvanceAuto to check my codes. Pulled a P0420, but then when I started it back up, all lights were off.
New gas cap appears to have done the trick!
#122
Scanned the codes today. Got two records P0420 Catalyst System Efficiency Below Threshold (BAnk1) and P0430 the same message for Bank2.
I reseted the codes but the light came back after 20 minutes driving.
I guess I will try to replace the fuel gas cap part 77300-33070 tomorrow.
hat did you do to remove and fix the issue?
Thanks
Thanks
#123
I am having same issues on my 2006 gx470. Bought used at 48,000 miles and have only had trouble since weather has gotten colder. After owning 30 days, same lights came on for me with a code P0158. Had Bank2 Sensor 2 replaced and light went off for a week and just came back on. Took to local mechanic and now codes is P0051 which is saying Bank 2 Sensor 1 is bad. I am worried there is an underlying issue and these replacements are expensive... any advice?
#124
I've been meaning to give these a try. One of the commenters there says that if you apply flux before inserting the wires into the shrink tube the solder flows much better.
Chip H.
Chip H.
ibgolfn
GX - 1st Gen (2003-2009)
43
04-04-21 08:58 AM
Tapoling
03-05-13 02:18 PM
ibgolfn
11-06-12 07:45 PM
DuCKsTeR
11-26-11 11:56 AM
