Parking Brake wire on 2005 GX470
Old 10-23-11, 07:29 PM
headcrash
headcrash's Avatar
Default Parking Brake wire on 2005 GX470
So I am about to install a new DVD head unit in a 2005, does anyone know where the parking break wire is on which harness and color? My original system did not have NAV or ML just standard CD so not sure where to look and tap into this wire from. Thanks for any advice
Old 10-24-11, 08:08 AM
mann777
mann777's Avatar
To get to the harness connector of the Parking Brake, it is a long job , You will have to remove the Console garnish Upper and the Panel Garnish and Console Box , you will see the Parking brake lever , release the brake and to remove the connector you have to unlock the nut holding it below, And you will see the Parking brake connector Switch . You can tap the wire from here if that is what you needed
To remove the Uper garnish Console it the one which is front of the Gear Lever, You need to disengage the clips which is on both the sides ( drivve rand passenger side and some towards the seat heater switch and some towards the rear of the Gear Lever, Here is the image, hope this helps.
And the console box it the clips which are around the panel of the Rear Console There are 4 clips engaged to this box. I have attached the images where the clips are engaged.
hope this helps
File Type: pdf
File Type: pdf
Old 10-24-11, 09:53 AM
headcrash
headcrash's Avatar
Default wire
Thx much for this going to tackle this project this weekend.
sexusc430
04-05-14 12:41 AM
B1TEM3
SC- 1st Gen (1992-2000)
09-15-08 11:41 AM
Tranman
03-18-05 10:06 AM
jucee187
Suspension and Brakes
08-12-04 10:08 PM
Quick Reply: Parking Brake wire on 2005 GX470
