HID retro?
Old 03-21-12, 12:43 PM
rominl
exclusive matchup
rominl's Avatar
just because factory halogen is fine doesn't mean there are no better options. some people are just funny they argue for the sake of it
Old 03-21-12, 12:50 PM
redrocks
redrocks's Avatar
...like ROK?
Old 03-29-12, 05:13 PM
RCsGX
RCsGX's Avatar
Still looking for a good pair of headlights so until I find them I mounted Lexus H3 capsules in my fogs. The capsules cost $20 so theyre cheaper than a pair of aftermarket yellow bulbs.
I also started making a HID relay harness and I found an empty factory relay socket in the engine bay. For those that like to work with their hands and make their own stuff I'll post a how to soon.
Old 03-29-12, 06:05 PM
rominl
exclusive matchup
rominl's Avatar
can't wait to read all the details!!!
Old 03-29-12, 07:30 PM
kphu
kphu's Avatar
RCsGX...do your thang man...ignore them crazy talk. If everyone is the same then it'll be like the humans in WALL-E.
Break new ground. I'm subscribed to this thread to watch your progression.
Old 03-30-12, 09:14 PM
bigguppy
bigguppy's Avatar
I just bought a gx today and I think I could use some real projectors. Especially when my last car had ls430. Looking forward to this.
Old 03-31-12, 10:14 PM
mann777
mann777's Avatar
Default HID Retrofit - Do it yourself
It is an easy process. All you need common tools. All parts picked up from TRS, no doubt the best leaders in the industry for innovative headlight upgrades. if you have any doubt that this retrofit cannot be done by yourslef. Then I suggest dont do it. Better give it some pro guys in town eg Lightwerkz, HID Retrofitz..
First you can pick up the products from TRS
Here is the link http://www.theretrofitsource.com.
Product needed.
1. Projectors - Bi Xenon Morimoto Mini D2S 2.0. kit
http://www.theretrofitsource.com/pro...roducts_id=236
2. If you do not want the Bi-Xenon and go for Single Xenon. Then you go for
then here is the Link.
http://www.theretrofitsource.com/pro...oducts_id=3181
.3. For the Ballast Kit - Morimoto Elite HD system.
http://www.theretrofitsource.com/pro...roducts_id=242
Tools
Refer my previous post, inclusive of the Dremel Tool handy when you need to grind the edges and reseal.
To begin
Very simple!
Step 1: remove front bumpers
Step 2: remove headlights
Step 3: Remove all the screws behind the headlight assembly and the rubber thing around the bulb opening
Step 4: pre-heat over on 220 degrees
Step 5: put the headlight assembly in the oven. (make sure to put it on top of something, i used wooden blocks so you wont melt anything.
Step 6: Leave it inside the over for about 10-15 minutes
Step 7: Take it out of the oven then pry the lens with flat head screw driver
Step 8: Remove the existing projectors and insert the new Morimoto ones ( Removal process is a bit longer time and must be done carefull.Ensure to seperate the Lens away while you work to remove the existing projectors
Step 9: Ensure the fit is rite and slide into the back of HL
Step 10: lock it by using sealant around.
Step 11: install the bulb holder or lock, then put the bulb in.
Step 12: test fit it into the truck again then aim it
Step 13: once properly aimed, put the headlight assembly and the lens in the oven for 15 minutes then re-assemble the headlight.
Step 14: Repeat for the other headlight
Step 15: Go get yourself a drink because your done
Induvidual Discount are available . Contact Matt. And he is quite technically sound guys if you need any questions on retrofit.
Old 04-03-12, 07:08 PM
kphu
kphu's Avatar
man777....as always your always the man!!!! both up
Old 04-04-12, 05:38 AM
chrisvr6
chrisvr6's Avatar
i want to direct my non related question to the hid pros in this thread: why is my drivers side hid not turning in auto with a harness installed? thanks.
Old 04-04-12, 06:02 AM
RCsGX
RCsGX's Avatar
Cheap parts, cheap harness....I dont know.
Not trying to be an azz, but this is a thread about my retro, not a kit. You might want to post your question here since you have a kit: https://www.clublexus.com/forums/gx-...diy-guide.html
Old 04-14-12, 01:22 PM
RCsGX
RCsGX's Avatar
Well guys Im taking the easy route and having my buddy Rich over at hidillusionz.com do my retro. Ive dealth with him many times in the past and he does excellent work and has a very quick turn around time.
To make a long story short...Im relocating to Florida and I made an offer on a home and the bank accepted the offer pretty fast, so im heading to Florida May 26.
Ive done retros before and I like to taking my time and since Im moving in a month I dont want to rush my retro. Plus my wifes pregnant (baby is due in July) so Im pretty much having to pack our house myself and break down our 125g fish tank w/ 20 fish in it...that combined with everything else I have to do before we move the retro is the last thing I have time for.
Anyway I'll post some pictures once I get everything back from Rich.....
Old 04-14-12, 09:29 PM
rominl
exclusive matchup
rominl's Avatar
well, not much else to say, but
congrats on your baby!!!! (our 2nd kid is due in 2 weeks)
congrats on your new house!!!!!!!
Old 04-14-12, 09:41 PM
RCsGX
RCsGX's Avatar
Thanks and congrats to you too!! This will be our 2nd child as well.
Old 04-15-12, 10:07 AM
clubsport
clubsport's Avatar
hey y'all,
last night i was driving to and from denver international airport in the rain and i thought the visibility from our factory headlamps is downright dangerous... i couldn't see very clear the lane markings or anything much... is this the reason why people do hid kit?
Old 04-15-12, 11:53 AM
RCsGX
RCsGX's Avatar
People go with HIDs in general because they put out more lumens (are brighter) than halogen bulbs, so you can see better. Obviously what im doing is better than putting a kit in our halogen projectors because a HID projector is made for HID bulbs so youll have a more concentrated / wider beam pattern but some people would rather buy a kit because its cheaper and easier.
To each their own......
Quick Reply: HID retro?
