arising issue: steering wheel shaking
Old 03-28-12, 05:27 PM
clubsport
clubsport's Avatar
Default arising issue: steering wheel shaking
hi y'all:
so today i took the gx470 on the highway and once is approached 70mph i noticed the steering wheel shaking... never before have i noticed this but today it happened i guess sporadically... just the steering wheel and nothing else... is this just the alignment? bad road? excessive speed? funky... lmk
Old 03-28-12, 05:35 PM
ALAN553
ALAN553's Avatar
Maybe you lost a weight, hit a pothole? Bubble in tire?
Old 03-28-12, 06:06 PM
clubsport
clubsport's Avatar
tires are brandnew - yeah could be the weights so i will have them rebalanced sometimes next week
Old 03-29-12, 06:08 AM
06isDriver
06isDriver's Avatar
most shaking in the steering wheel is from mis-balanced tires. If you can go to a place that uses a road force balancer, that'll be your best bet.
Old 03-29-12, 06:32 AM
chrisvr6
chrisvr6's Avatar
mine doing this too now. new tires though. ball joints maybe bearings, tie rod endss?
Old 03-29-12, 06:42 AM
RCsGX
RCsGX's Avatar
Sticking caliper.
CurlyG (09-24-22)
Old 03-29-12, 08:41 AM
clubsport
clubsport's Avatar
yea from what i read the force balancer is the way to go first, i wonder if firestone has them:
other causes from searching: steering wheel column spring worn out, bearings, alignment, etc.
this only started after i had my spoiler on, but that can't be the cause... i will have to try the force balancer first then, thanx
Old 03-29-12, 10:51 AM
mann777
mann777's Avatar
Steering issues are of many causes. Most prominent on GX are the Front differential Support and Dynamic dampers are mfr defect. Normally they trigger the vibration on the steering , which effects the sliding yoke on the steering. Most of the GX 03/04 Models had this symptom and Lexus issued a TSB to sort this issue.. Changing the above parts have removed this issue. I had this myself on my GX and as it was out of the 50,000 Comprehensive warranty.Now if you model within this year, you may want to look at the above.
Old 03-29-12, 12:19 PM
clubsport
clubsport's Avatar
hey mann777,
thanx for the help, hey if i wanted to replace the spring how long is the job? is it a few hours?
thanx
Old 09-18-22, 11:39 PM
CPTSOLO
CPTSOLO's Avatar
Likely a tire with a flat spot or a bent wheel.
Rotate the tires from front to rear. If it improves then definitely tires/wheels problem.
If it does not improve then problem is in the car, could be struts or worn ball joint or bent axle..
Old 09-19-22, 07:11 AM
IanB2
IanB2's Avatar
This thread is more than 10 years old...
matts6887
08-15-22 01:58 PM
GregoryNP
06-05-14 09:10 AM
kmy
07-21-11 07:35 AM
sevenall
07-17-08 12:53 AM
Quick Reply: arising issue: steering wheel shaking
