Broken cable in rear seat, anyone know how to access???
Old 09-21-12, 12:35 PM
Lemleymf
Lemleymf's Avatar
Default Broken cable in rear seat, anyone know how to access???
I folded down my rear seat the other day and it wouldn't unfold. I took it to Lexus and they wanted $600 to replace a broken cable in the seat. After that estimate I decided to do it myself. I found the parts I need on Sewell for about $50. The problem is that I am having a hard time getting access to the cables in the seat. Does anyone know how to get access to the cables in the seat or how to remove it so I can figure it out from there?
Old 09-21-12, 01:20 PM
redrocks
redrocks's Avatar
Holy s___! $600. Lexus is so, so overrated ! Why should this cable break?
Old 09-21-12, 03:58 PM
Kermee
Kermee's Avatar
Obviously it takes 5 hours of labor to fix with a $50 part
Cheers,
Kermee
Old 09-23-12, 10:20 PM
BlairC
BlairC's Avatar
hmmm, seats are a safety system right? shouldn't those be warrantied for nearly the life of the vehicle?
Old 09-24-12, 02:52 AM
mann777
mann777's Avatar
First, lay the rear seats down flat and folded over. Then to the left and right of each folding seat you will see a visible panel in the sides of the vehicle that easily open. Then get a socket wrench with an extension and simply remove the two bolts per each seat. You can then easily lift the complete seat assembly out of the rear of the car. I would recommend that you thread the bolts back into the plates so you will not lose them and then replace the panel.
Old 09-25-12, 09:58 AM
Lemleymf
Lemleymf's Avatar
Thank you mann777, I'll give it a shot this weekend.
MSRX
07-01-18 01:06 AM
ejthomp
12-23-13 11:01 AM
JaytdotP
07-24-10 10:56 AM
looknow12
GX - 1st Gen (2003-2009)
05-16-07 03:06 PM
spxChrome
04-22-03 11:32 PM
Quick Reply: Broken cable in rear seat, anyone know how to access???
