DIY Brake Rotor - Brake Shaking/Vibration FIX - Warped Rotor FIX
Old 11-21-12, 10:24 AM
prwdmd
prwdmd's Avatar
Awesome write up! I'm glad I found your post because I am planning on doing this exact job later this week. So it's OK to reuse the old shims? Is there any benefit to getting new ones?
Old 11-21-12, 09:45 PM
Booyah
Booyah's Avatar
Ok This didnt get answered the last time!
Is it beneficial to replace the rear rotors and pads at the same time? Does it need to be done?
Old 11-22-12, 03:09 AM
ALAN553
ALAN553's Avatar
Brakes get replaced when they are worn out, the rear will usually outlast the front brakes, sometimes by double the milage.
Old 11-26-12, 07:07 AM
mann777
mann777's Avatar
Booyah Lexus advises for skimming the Rotors twice before full replacements, provided the requirements are met for skimming. But the stealerships go in for replacement. ( Big Bucks $$$$ )
Old 11-26-12, 10:07 AM
Booyah
Booyah's Avatar
Yea but I hear not worth it with the lexus. I can get the rotors for 110.00ea and the pads for 40.00 bucks, and I will do it myself so I will be saving money lol and knowing I got all new OEM parts that should last me longer hopefully.
Old 07-22-13, 05:37 PM
dwhaley
dwhaley's Avatar
Great write up and pics. Thank you.
Old 07-24-13, 09:52 PM
vxphan
vxphan's Avatar
Great DIY job. Nice pictures. Unfortunately, I did exact the same two months ago with same parts and the famous warping is back and worst. That how fast it is.
I am thinking about replace the pads one more times with Ceramic pads.
Old 07-24-13, 10:42 PM
stiles_s
stiles_s's Avatar
I took a different approach and installed some HAWK pads (LTS?) on rotors that were starting to feel like they were warping (actually a deposit buildup, IMO). All shuddering/oscillating is gone, brakes are working great (other than an annoying squeal at times). The OEM pads are really prone to leaving deposits, especially after a hard stop where you stay on the brakes and transfer material. They're low dust, work well when cold, and have pretty good feel, but the issue with deposits was enough to send me elsewhere for pads.
Old 07-26-13, 02:20 PM
Booyah
Booyah's Avatar
Just ordered my some Akebono Front / Rear pads and OEM rotors from toyota. I will be doing the job when all parts arrive--cant wait to have smooth braking again lol
Old 07-29-13, 12:55 AM
schan1w
schan1w's Avatar
Nice write up. I did this a few months back, but my rotors were rusted in place and impossible to remove. I had to go at it with pretty hard with a hammer in order to break the seal. Had no idea that one has to hit it with full force to break it loose.
Old 07-29-13, 09:16 PM
Booyah
Booyah's Avatar
Originally Posted by Taco_Kid
does it see rain and snow where you are? i would use some anti-seize paste on the slide pins and just a dab on the pads shoulders that slide up against the caliper when they slide in, etc.
Ummmm Heck yea Anchorage Alaska lol. I will get some paste!
Old 08-04-13, 06:56 PM
Booyah
Booyah's Avatar
I tried this today and I did everything possible to get my ONE rotor OFF!! It would not budge after hitting it several times with hammer lol--- ANY suggestions.
I just put it all back together after 2 hours of pissing me off lol
Old 08-04-13, 07:14 PM
mitsuguy
Maintenance Moderator
mitsuguy's Avatar
hit it harder... if that doesn't work, have a bigger friend hit it harder... still doesn't work, get a real hammer and hit it even harder...
this applies for all rotors that are not bolted to the hub or part of the hub itself...
Old 08-04-13, 07:20 PM
Booyah
Booyah's Avatar
LOL----Yea guess I need bigger hammer cause nothing is holding it on for sure !!!!
Old 08-04-13, 09:18 PM
mann777
mann777's Avatar
Use a Mallet and give a hard hit equi distance all around, I had mine trouble taking off sometime back, You may have to hit around 20-25 times around the rotor, but dont hit around the hub side. ( Caution )
Quick Reply: DIY Brake Rotor - Brake Shaking/Vibration FIX - Warped Rotor FIX
