CEL - VSC and VSC TRAC Lights
Hello Everyone,
All of these lights came on for no apparent reason. I check with computer based OBD reader, and I'm getting code P0049 (Turbo/Super Charger Turbine Overspeed). Weird code considering the lack of turbo or super charger on the GX. I cleared the codes, but all came back after a few miles of driving. Any idea what code P0049 is pointing to? My truck is 04 GX470 with 74,000 miles.
Thanks in advance
Thanks in advance
Not sure if I had that exact code, but I had those same lights occasionally come on in my '04 GX at around 100k miles.
Through some web/forum searches, I ended up replacing the brake switch. It took all of 10 minutes under the dash.
Good luck!
Good luck!
I think he means Brake Light switch [ Its directly attached to the top pivot of the brake pedal ] Not sure why that would trigger all of the lights.
Yes I'm sure, pulled it 3 times so far. It just doesn't make any sense. Maybe I should try pulling with another reader.
VSC, TRAC systems all have to know that you've pushed on the brake pedal somehow, makes sense that it'd be via the brake light switch, since it's literally the first sensor/switch to know what you've done.
Again, this may or may not be your problem, as I never got an engine code, just the symptoms matched. Also, it's a cheap part to replace.
Niceeh
LX - 3rd Gen (2008-2021)
20
09-24-20 09:40 PM
