Getting 90k Service done - anything else I should do?
I'm getting the 90k service done. Major items are Timing Belt, water pump, fluids, oil, filters, and etc. I'm also going to have them do the x-fer case and differential. Got a quote for $1056 for all of the above.
Anything else I should consider doing? Radiator hoses? Thermostat? Seems like those would be cheap insurance since I'm already in there.
I'm having trouble figuring out when the x-fer and diff oils get changed. I see conflicting information out there. I don't even see it in the lexus schedule for some reason.
You won't see it, it's probably one of their "lifetime" oils. If you're at 90K change it. I would save the $200+ they're charging you though and do it yourself w/ some Amsoil 75w90. It's good for up to 100K miles. You don't need to jack your GX up and it'll take you 30mins if that.
What about front gear oil, did you do yours without jacking up the car? Any suggestion on pump? I used the one from autozone it fell apart.
I did mine rear differential and transfer case, waiting on engine oil change than I will do front differential. it was really easy to do, make sure you change the washers, it is bit messy and the pump to put oil on is usually junk and falls apart.
I would like to add, lube the drive shaft with Mobil 1 pink grease, 6 zerks fittings. It made a huge difference when I stop my truck, no kick or clunk.
I've been using a pump I bought years ago from Amsoil. Four vehicles later and it's still going strong.
http://www.amsoil.com/shop/by-produc...mp/?code=G2039
And yeah I used all new crush washers and drain / fill plugs too.
I have some new hood struts coming in tomorrow, mine are already blown. First vehicle since I was 16 to even need new hood struts. They'll hold the hood up but if there's any movement it'll come down like a ton of bricks. I was cleaning the engine bay earlier this week and the hood came down, I was about to move my head just in time but my shop light wasn't so lucky. Somehow it got wedged in by the passenger side headlight and in the process the little catch hook bent so I couldn't open my hood from the interior hood release. I ended up using a long flat head to open my hood and I bent back the catch hook and all is good.
What is lame is I asked them to do the Water Pump and Thermostat at the same time, and they didn't even give me a labor discount for the Thermostat, so it is $200 for them to replace a $26 part that they pretty much have full access to when doing the timing belt....
When they say they are doing the "Timing Belt" make sure they are alos replacing the tensioner and idler pullys. My dealer just lists the Timing Belt part number when doing the Timing Belt Replacement, so I think that is all they are replacing.
I was intimidated by zerk fitting, never done it, it was easy. Definitely do the front differential drain and refill, I used mobil 1 synthetic with LS (Limited Slip) on all 3, front were the dirtiest and only about quart came out, I filled it with 1 1/2 quart till started to drip from top.
Do you know what the FSM says about fromt Diff? How much fluid on drain and refill?
That doesnt make sense to me, I put in 1 1/2 quart which equals to 3 pints ONLY in front differential.
You are saying I should of put 3 pints which equal to 1 1/2 quart in BOTH the transfer case and front differential?
EDIT: Searched more and Mann777 had a post up it is infact 1 1/2 quarts ONLY in front differential. So, you would more for transfer case.
https://www.clublexus.com/forums/gx-...-tutorial.html
Where did you get that quote?
Front Diff: 1.5qts.
Transfer: 1.5qts.
Rear Diff: 3.15qts.
