GX460 Suspension on a GX470
So after some very preliminary investigation, it seems like the non AHC suspension from a GX460 will work on our GX470s. (For those that don't know, the GX460 has the air suspension as an option). As I continue to investigate suspension options, it seems like the GX460 suspension might check a lot of boxes: traditional coils, affordable, presumably retains a Lexus type ride. I want to keep the stock ride height and want a comfortable ride. While I can see the benefits of the air suspension, with over 100K miles mine is already going out.
I'm not yet convinced enough to place an order and need to confirm it will work. But I would love to hear any thoughts about the matter.
Well, it looks like it will work, but it doesn't look like it is a very good idea. According to this: http://www.pradopoint.com/showthread...sion-fit-a-120
It looks like the 150 series springs and shocks, while they would fit, have totally different characteristics. I also didn't realize the GX460 is almost 500lbs heavier than a GX470. The springs are actually shorter with a higher spring rate.
I think I need to investigate a way to get OEM Prado shocks and springs.
devD
GX - 1st Gen (2003-2009)
01-18-17 09:38 AM
