Power Outlet Control Button
Hi guys! :-) I have a question. Is the power outlet control switch supposed to be lit? I noticed that my other buttons down there, mirror de-fogger and such are illuminated, but that one button is not. Would this be a blown bulb or is it not supposed to be illuminated?
You can get an led from radio shack. Remove the switch then turn the bulb out with small screw driver . Then you can bend the wires out and pull the bulb out take that to radio shack and you can get a replacement. then re-install if it does not work swap the polarity of the bulb. Its also just as easy to order a new one from sewel lexus or go to your dealer and order the bulb you wont have any shipping cost
Here's the parts list for the dash switches:
http://lexus.sewellparts.com/oem-cat...X470-2009.html
Chip H.
Chip H.
