LED headlight bulbs
Nice pictures but I couldn't stop noticing that it's dark and still 92 degrees!
It was probably mid-80s. I'm pretty close to the coast, so it won't dip below 80 for another month...
I've run these since last summer. They are passively cooled, no fans.
If you stand 5 feet away you can see a "split" in the center of the low beam because the LEDs are side firing, otherwise they work great. I went with the "warm white" aka Phillips Luxeon so they are closer to white (the white are Cree and more blue).
Low beams
http://www.aliexpress.com/store/prod...349414282.html
High beams
http://www.aliexpress.com/store/prod...349471607.html
Low beams
High beams
Just got done with the Installation.
It took forever almost 3 hours because the plug wouldn't go in far enough where the terminals meet because of the fat plug OPT7 made. I had already given up but my wife helped me to get it done. My thumbs hurt like.......![Sai](https://www.clublexus.com/forums/images/smilies/SaiyanSmilie_anim.gif)
I thought it was easy......![Sad](https://www.clublexus.com/forums/images/smilies/sad.gif)
But after everything got done I am way happier than the results... Check out the pictures I just took.
It took forever almost 3 hours because the plug wouldn't go in far enough where the terminals meet because of the fat plug OPT7 made. I had already given up but my wife helped me to get it done. My thumbs hurt like.......![](https://www.clublexus.com/forums/images/smilies/SaiyanSmilie_anim.gif)
I thought it was easy......![](https://www.clublexus.com/forums/images/smilies/sad.gif)
Also, did you use the reverse polarity pigtail included? I had to on mine. As I write this, I wonder if you "forced" the plug in backwards, which would enable the correct polarity, but also means you had the plug turned 180 degrees, such that the 'fat tab' was not lining up with the spring clip side of the adjoining female plug. Yes, if you did that, you worked (unnecessarily) hard!! The included pigtail (NOT the ballast one) reverses the polarity for you and enables easy installation.
But, if you had everything correct, then I am sorry it was such a chore.
![](https://cimg5.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x1124/gx_light_a84753907083102a997cf0a0361f694849409146.jpg)
I didn't even bother to use the other 2 cables in the separate box.
I tried to force the plug in both sides but it wouldn't slide in and the pins weren't connecting even when they did it would just turn off as it wasn't all the way in.
Finally I forced it in and tested it by knocking on it and moving it so it doesn't go off and been working fine.
I hope not using the third cable would be ok .... Let me know if it's not? and I will add the third cable.
BTW....
I am not handy at all so no experience... But learning as I go because of awesome people on this forum.
Oh no! I was hoping I was wrong. I can see now why you struggled with it so long! With lots of cursing, I'm sure.
I don't think you need the other plug, but it would have been much easier (too late now?) and it may actually stay connected long-term since all the clips will be clipped.
So far connections are holding up good no issues with 2 days of driving. Hopefully there will be no issues in the future as well.
@degmla
![Hello](https://www.clublexus.com/forums/images/smilies/hello.gif)
Sincere thanks to you bud for mentioning OPT7 Lights. I am loving this MOD on my GX.
@OP
Sorry for Hijacking your thread. But you might want to go this route and upgrade. (Suggestion)
@degmla
@OP
![Agreed](https://www.clublexus.com/forums/images/smilies/boink.gif)
@degmla
@OP
Sorry for Hijacking your thread. But you might want to go this route and upgrade. (Suggestion)![Agreed](https://www.clublexus.com/forums/images/smilies/boink.gif)
@degmla
@OP
I am not HID/xenon expert but I am loving these LEDs. They make a huge difference over standard Halogens (it's a lot of light). Last week we went to Boston from CT and travelled in the night, that's when I got to test them for the first time in the night. All I can say is... It's a lot of super bright white light and lights up the road
Even road signs from far start getting noticeable.
![Dance 1](https://www.clublexus.com/forums/images/smilies/dance1.gif)
I am not HID/xenon expert but I am loving these LEDs. They make a huge difference over standard Halogens (it's a lot of light). Last week we went to Boston from CT and travelled in the night, that's when I got to test them for the first time in the night. All I can say is... It's a lot of super bright white light and lights up the road ![Dance 1](https://www.clublexus.com/forums/images/smilies/dance1.gif)
Does anyone here happen to have a good link to the correct kit? Link on previous page is not working. I copied and pasted in address bar but other items came up with options I wasn't familiar with. Any help would be appreciated!
I have the Xenon Depot HID's for my fogs (9006) in my 2006 Lexus GS300 and headlights (H11) in my 2004 Lexus GX470, and they all work like a charm regardless of weather. These HID's were as plug and play as they come (on the GS I had to flip the polarity). I tried LED's as my DRL/High Beam lights from Xenon Depot with the canbus adapter and the DRL lights were white and nice but the high beams were non-existent so I had to go back to a halogen bulb to give me my high beams back (and also the yellow DRL light).
If you are looking to buy LEDs we talked about on this thread the link is below:
https://www.amazon.com/OPT7-Headligh.../dp/B00VNBDWPK
Never mind...I managed to finally sit at the computer and figure it out! Problem is that there are way too many pros and cons to LED vs HID and I just can't figure out which to buy.
