GX470 w/Nav Solution for Aftermarket Stereo?
#181
Did you do the install yourself? Any problems pop-up? Dying to do this but I think you have to adjust the volume from your old unit before moving to the Phoenix and my volume won't work on my old unit.
#182
@Yaahms - See those 2 fan icons right below the 2 defrost icons at the very bottom of the screen? One is a little fan and the second is a bigger fan. That's where you adjust fan speed. You can also turn the AC on or off by touching the AC icon between the "Dual" and "Auto" icons.
Congrats!! you are going to love this system.
BeEvil
BeEvil
#183
Coolie - yes I installed it. The first problem is the lack of instructions but that was easy enough to get through if you have any kind of experience with this sort of stuff. The next problem was that the amount of wires that need to go back in the hole along with the unit can overwhelm the available space so you have to do a bit of creative tucking to get it to fit. Again - not a super big deal.
#184
Damn. That's unfortunate. All mine work. Is this the DLC Android system? What default vehicle did you use from the menu? I'll have a look at mine. I can't remember which the installer used in mine.
#185
#186
I am not sure of the DLC question, but this thread is where I found the link for this particular unit so I think so. When I got it, it was listed as IS300 in the settings. I changed it to Prado to attempt the fix but it still functioned the same. I did notice that both the factory harness and the unit harness both had unused connections, but they didn't fit each other. Promise.
#188
You might have received the wrong harness. On my Phoenix, all of the factory harness is plugged in to connections on the unit.
I would assume all the radio plugs need to be connected to work properly.
Th unit you have, is that the one where you need to take apart the factory AC controller?
#189
#190
Ugh, I know with our Phoenix unit, it uses a Buick car setting for the AC, not Lexus. Makes no sense to me. However, it works well. I don't know anything about your unit. I do know there are different harnesses or adaptors. I remember a person waiting for a harness because they sent the incorrect one.
I hope someone with your same unit jumps in.
Good luck,
B
Good luck,
B
Yaahms (11-06-18)
#191
BeEvil (01-07-19)
BeEvil (01-07-19)
