Gear selector getting stuck
Old 07-01-16, 03:18 PM
HMCGARY
HMCGARY's Avatar
Default Gear selector getting stuck
Lately I noticed that when I get in the truck and start it up the gear selector want go into gear. Sometime I have to turn the truck off and restart it and work the selector and finally it moves. I was wondering if anyone else has experience the same problem.
Old 07-01-16, 04:40 PM
180ls1
180ls1's Avatar
How does it drive and shift? My guess would be something in the gear selector linkage is lose or warn.
Old 07-01-16, 05:56 PM
HMCGARY
HMCGARY's Avatar
It drives and shift with no problem. I had to use the gear selector release button to get in gear now.
Old 07-01-16, 06:23 PM
BlackCat81
BlackCat81's Avatar
I had a metal pin fall out of mine. Mine would still shift into P N D and R, but wouldn't go all the way down. It became loose and sloppy. I bought a replacement shifter on eBay. Any 03-09 will work, and is much cheaper than a new one.
Old 07-01-16, 06:25 PM
HMCGARY
HMCGARY's Avatar
Thanks for the info
Old 07-02-16, 05:07 PM
IanB2
IanB2's Avatar
Is it sticky, or locked out like the car isn't registering it's safe to shift from park? Maybe a bad brake light switch?
Old 07-02-16, 05:19 PM
HMCGARY
HMCGARY's Avatar
It's more locked out. I have to use the button release to get it in gear. I think I will replace the brake light switch first! Thanks
Old 07-02-16, 06:58 PM
BlackCat81
BlackCat81's Avatar
When you push the brake pedal do you hear the shift detent release in the shifter?
Old 07-02-16, 07:06 PM
HMCGARY
HMCGARY's Avatar
Not sure, will try now
Old 07-02-16, 07:16 PM
HMCGARY
HMCGARY's Avatar
Just tried it and don't hear everything
Old 07-02-16, 08:15 PM
BlackCat81
BlackCat81's Avatar
Well you either have a bad brake switch or the shift detent solenoid is bad.
Old 07-05-16, 10:27 AM
bbrowncods
bbrowncods's Avatar
See if your brake lights come on also.
Old 07-07-16, 05:23 PM
HMCGARY
HMCGARY's Avatar
The brakes light come on. Now the selector is working sometimes. I did notice when the selector wont move into gear the abs, vsc trac, vsc off and skid control symbol lights up and the selector won't move. When the lights go out the selector moves ok.
Old 07-08-16, 07:25 AM
IanB2
IanB2's Avatar
Have you scanned for codes?
Old 07-08-16, 02:47 PM
HMCGARY
HMCGARY's Avatar
No, I havent but I did notice when I touch the brake pedal the lights go off!
rocdude
NX - 1st Gen (2015-2021)
15
07-10-17 05:10 AM
k3vo
GX - 2nd Gen (2010-2023)
05-11-11 05:05 AM
Zinda
03-01-09 08:19 PM
Quick Reply: Gear selector getting stuck
