GX - 1st Gen (2004-2009) Discussion topics related to the 2003 -2009 GX470 models
Best timing belt kit to order for 2006
Old 09-13-16, 10:12 AM
Roboworm
Roboworm's Avatar
Default Best timing belt kit to order for 2006
I am new here and have researched the forum for best answer but still not satisfied. What is the consensus of this forum group on which timing belt kit to order for a 2006 model. Do you need to replace all the seals that come with some kits or is that overkill. My Gx has 137,00 miles. Thanks again.
Old 09-13-16, 09:11 PM
Barnesie
Barnesie's Avatar
This is a good kit. Has the tensioner, two idler bearings, and water pump which are all a must in my opinion when changing the belt.
https://www.amazon.com/gp/product/B0...=ATVPDKIKX0DER
Old 09-13-16, 09:43 PM
EddieK05
EddieK05's Avatar
The above kit is the same one I got, although from a different seller. It's complete with everything being quality OEM parts. Had it installed last week by my Indy mechanic, only parts he would have added to the kit which I purchased from him are the thermostat and drive belt.
Old 10-25-16, 11:08 PM
ipaniwala
ipaniwala's Avatar
Thanks!
ll buy this
How much should a mechanic charge me as labor in S Florida ?
Old 10-25-16, 11:20 PM
EddieK05
EddieK05's Avatar
Mine charged me $400. Ended up being $500 with him replacing the thermostat and drive belt while he had it apart.
Old 10-26-16, 12:04 AM
ipaniwala
ipaniwala's Avatar
Thanks!
Newbie question
Should I plan to change thermostat and drive belt ahead of time or wait for my mechanic to recommend the change ?
Old 10-26-16, 06:08 AM
EddieK05
EddieK05's Avatar
Originally Posted by ipaniwala
Thanks!
Newbie question
I'd plan for it and buy the parts in advance, would have saved me about $50 over what he charged me for the parts and you definitely want to go ahead and change those two parts while he's already in there.
Old 10-26-16, 11:07 AM
IanB2
IanB2's Avatar
Change the t-stat for sure while it's apart as you'll lose coolant if you choose to do it at a later date. The accessory belt can be done whenever really, but it's got to come off to do the timing belt/water pump job, so there's really zero additional labor you should be charged.
Old 11-03-16, 08:17 AM
ipaniwala
ipaniwala's Avatar
Adding a link to thermostat assembly (part no 7) …looking at this explained why it made sense to change this part right now!
5. Water pump
6. Gasket
7. Thermostat
Gurus,
Any recommendations on which thermostat or drive belt to buy ?
Thermostat
https://www.amazon.com/gp/product/B000C809HY
Last edited by ipaniwala; 11-03-16 at 08:49 AM. Reason: Adding diagram for thermostat
Old 11-17-16, 02:03 PM
sesser
sesser's Avatar
First, this site has be a huge help for me since buying my GX two years ago. So, thanks to everyone... the information here is much appreciated.
I'm having to replace my secondary air pump in my '05 and since it involves pulling off the manifold to do so, I'm also having the starter replaced since it sits right next to the pump. Mine has 170k on the ODO and the belt was changed at around 95k. Would it make sense to have the belt replaced at the same time while the shop is tearing it apart for the air pump/starter fix? Or are the two things different enough that it wouldn't matter in terms of cost?
Old 01-18-17, 09:47 AM
gsp480
gsp480's Avatar
I just order the aisen kit from rock auto. I get the oem belt from Toyota along with Toyota fluids.
Old 01-19-17, 08:10 PM
DiabloX22
DiabloX22's Avatar
Your question about the seals. If they are leaking, no brainer! But you cant look at a seal and tell if its going to last 1 day or 100k more miles. When I get my stuff done, my motto is DO IT! Since they are in there. You dont want oil on your new belt. My history says my water pump was replaced, there is a sticker for the belt. I would think Lexus would do the low ball scam or be upfront and say, You are going to need seals, pulleys tensioner, rollers, EVERYTHING! Its a big service, cheaper than a new engine or fixing a broken 1
Old 01-21-17, 09:42 PM
chitown40
chitown40's Avatar
Also consider replacing the drive belt tensioner pulley while you are putting everything back together. Mine went out at 103k. Toyota and Lexus will not sell the pulley separate from the tensioner assembly, but the OEM is actually Dayco. Advance Auto Parts sells the Dayco brand tensioner (where Oreally's sells Gates brand - the Gates sells a separate pulley but it does not fit the OEM tensioner). With a coupon code online I get the entire tensioner assembly for $40. I just replaced the pulley as my tensioner works fine. Threw the tensioner assembly and old original pulley on the shelf for another day. You can source a new bearing for the old pulley and press it in for very cheap. Now you have a spare or a cheap new part to sell/give to a buddy.
Old 01-22-17, 02:18 AM
Dallasguy1
Dallasguy1's Avatar
Also I would like to ask I was checking eBay and there are some kits available for 80$ and some are for 180$ both are after market parts. Is there any brand we should look for ? Thnx
mekelly
07-10-16 06:17 PM
Braz60
03-12-16 06:16 PM
tbilisi79
07-16-14 04:22 AM
istundra
02-04-14 11:16 AM
k311in
02-24-11 06:29 PM
Quick Reply: Best timing belt kit to order for 2006
