Belt Squeal on startup
Old 12-20-16, 09:19 AM
cardboy008
cardboy008's Avatar
Default Belt Squeal on startup
I have an 03 with 110k miles. Timing belt was done at 88k. On cold start, I hear what sounds to be a belt squealing for 3-5 seconds, but then it goes away and doesn't make any noise until the next cold start. Any ideas on which belts (or if not belts then what) need to be looked at?
Old 12-20-16, 10:47 AM
ALAN553
ALAN553's Avatar
if serpentine drive belt has never been replaced, that might be the first start
cardboy008 (12-20-16)
Old 12-21-16, 06:19 AM
BlackCat81
BlackCat81's Avatar
Mine used to do it occasionally after sitting for a week or longer without starting, with a brand new belt. It's probably the tensioner getting weak, but now that I drive it every day, I haven't heard it.
cardboy008 (12-21-16)
Old 12-22-16, 07:35 AM
techrep
techrep's Avatar
Like stated above .. either a worn belt or idler/tensioner pulley.. all easy fixes.
Old 01-18-17, 09:32 AM
gsp480
gsp480's Avatar
Same issue, started as the temps dropped here in ga. Having the timing belt work done and a new serp belt put on so hopefully that fixes the issue.
BryanH19
05-09-19 08:09 AM
DCarter197
04-19-18 01:01 PM
sc300work
Performance & Maintenance
06-05-15 02:39 PM
sc400123
16
09-07-07 05:38 PM
kaotiq
24
03-18-05 07:23 AM
Quick Reply: Belt Squeal on startup
