Help with Electrical fault
Old 10-01-17, 11:01 AM
Scottrolli
Scottrolli's Avatar
Default Help with Electrical fault
I have a 2006 GX470. On Sept 1 and Oct 1 it would start and run, but the shifter would not move to reverse. I checked the OBD and there was no power. The following lights were on: Brake/ABS/airbag/differential lock/check engine/tire pressure.
The first time it happened I had it towed to lexus dealer. When it arrived there were no issues they could find.
Today it happened again-I have driven this vehicle everyday hoping it would happen so I could diagnosis it. I went to get a needle nose plier to pull a fuse and when I got back to the car it was fine-no issues.
I noticed that the AC INV relay housing is cracked. I will replace it. Any ideas??? It was cool, but not damp both times this has happened.
Old 10-01-17, 03:53 PM
EddieK05
EddieK05's Avatar
Check your brake switch. I had a similar issue, and it was due to a faulty brake switch.
shabbyblue
03-22-21 01:57 AM
peterls
19
06-10-16 08:39 AM
MEQ
06-17-11 04:00 AM
specvser04
SC- 1st Gen (1992-2000)
06-02-09 01:59 PM
wayne86
10-24-08 12:52 PM
Quick Reply: Help with Electrical fault
