Are these the right manifolds to order for my GX?
Old 04-23-18, 01:04 PM
Opeechee
Opeechee's Avatar
Default Are these the right manifolds to order for my GX?
Hey guys,
Going to get rid of this annoying ticking sound. Dealer quoted me over 3K even with friends and family, so I'm going to save a lot buy buying the manifolds myself. I just need to make sure that these are the right ones... I have a 2006 GX. There were 2 other options on the site, these being the most expensive by $100 each. I've read a lot of threads and posts but just want to be sure and put my mind at ease before spending a grand on these parts.
Also would you guys recommend doing any other replacements while I have the tech in that section of the truck? I'd rather spend the money now rather than going in there again. Someone on the GXOR fb page suggested replacing the alternator and the starter if you are getting this done.
So far I've had the timing belt, pump, radiator, drive shaft and all fluids replaced on my 175K mile GX.
Thank you very much for your help, I'm not a gear head and doing my best to learn.
Old 04-23-18, 02:01 PM
chiph9
chiph9's Avatar
The OEM part numbers are:
1714050060 - Manifold sub-assembly, exhaust, right
1715050050 - Manifold sub-assembly, exhaust, left
Original price on each is $699 USD, but they're sometimes discounted to $525. They include the manifold, the catalyst, and the bolt. They do not include the gasket, block studs & nuts, or heat shield.
So maybe you can use those p/n to cross reference.
Chip H.
Opeechee (04-23-18)
Old 04-23-18, 02:11 PM
Opeechee
Opeechee's Avatar
Thanks Chiph, does that mean that these parts in the screen shot will not work? Or are they missing catalst and the bolt? In the description of these parts it says it has extra Rhodium, so I'm guessing it has the catalytic converters in it still.
A guy on Gxor said that they would work but I just wanted a second opinion.
Old 04-24-18, 05:00 AM
chiph9
chiph9's Avatar
I can't see how you found those parts so there's no way for me to confirm for you that they're compatible. I'd put the part numbers I found for you in Amazon and see what it comes up with.
Chip H.
Myke215
GX - 2nd Gen (2010-2023)
12-30-12 06:56 PM
stevobentz
GX - 1st Gen (2003-2009)
15
12-01-12 01:25 PM
Smileyboy
03-26-12 06:41 PM
petsb10
12
10-07-05 08:42 AM
LexusBob
06-22-05 09:15 AM
Quick Reply: Are these the right manifolds to order for my GX?
