Water sloshing noise
I am sure there absolutely has to be a topic on this, but using search with "sloshing" didn't bring up much and I can't figure out what else to call it. That said, I can hear tons of water somewhere behind the dash/firewall area. The interior is completely dry, so I'm guessing it's just a drain that's full of debris in the engine compartment. It used to be intermittent and would go away after driving a few minutes, but now it's a constant thing, particularly since we have had a mix of rain and warm weather which is causing tons of debris to come down from the trees where I park.
Can anyone point me in the right direction? It almost sounds like my friends Touareg that seemed like it had over a gallon of water in the frame when we finally opened the drains.
Probably clogged up sunroof drains, get under the truck and start pulling rubber plugs from the frame/body out till you find the source. You can run some heavy weed whacker line down the drains to clean them out so it doesn't happen again.
shakazulu (05-14-18)
Agree. Sunroof drains, but also check the A/C condensation drain. There are two of those - one up front, and one in the back for the rear A/C unit.
Chip H.
Chip H.
IanB2 (05-15-18)
I am just now about to get to this today, but I suspect that is what it may be. The sloshing got really pronounced in the past week since warm weather finally hit and the AC has been on. Also just realizing there is no water under the after I park it like would be normal.
I dont want to start just pulling rubber hoses...
thank you all !!
Try posting in the GX460 section since you have a '17, the principles are the same but we don't have 460's to share pics from.
garfull
RX - 3rd Gen (2010-2015)
05-08-10 11:31 AM
