Quote:Originally Posted by tobe1424 My cup holder recently got stuck in the folded in (closed) position. Before happening, it would get stuck but then I would tap it a few times before ejecting.
Now it's simply stuck. Any advise? Please help
Access to two 10mm bolts holding console bracket.
Console removed
Access to two 10mm bolts holding cup tray.
Repaired cup holders
Gain access to the plastic cover my unzipping portion of the rear seat and remove cover w Phillips screwdriver. Unbolt console bracket with 10 mm socket. Remove console. Unzip end of console and remove two 10 mm bolts. Cupholder will slide out for examination. I kept working with mine and finally got the mechanism to work and it seems fine. Reinstalled in the vehicle. It was actually pretty simple. Reply
