caliper replacement question
i need to replace front caliper, seized up. don't feel like fixing them.
what parts beyond the calipers would you switch?
caliper is here:
https://www.rockauto.com/en/moreinfo...sn=858&jsn=858
(would you get this one?)
any other components I need? holding pins? brake bleeder? caliper pins?
i'm pretty new to doing this. thanks for all answers
caliper is here:
If you're having to replace calipers frequently like I did, you might want to look at switching to the '10-13 spec GX460 front brakes, calipers and rotors required, pads are the same. It's been a few years without a seized caliper now, whereas I seemed to be replacing one a year on average previously. Everything bolts right up.
I'll probably seek out some GX calipers from junkyard and have them re-built, in preparation to replace my originals.
GX470 front brakes are too small. The better fix is to do it right/better.
As example:
https://www.rr-racing.com/RR-Racing-...gx4fbk0002.htm
caliper is here:
caliper is here:
Whoa. Seizing up annually? I am still running the OEM's from 2006. Your issue seems odd, why were they seizing up annually? Was it the same or different brand each time?
thank you for all the answers.
in terms of replacing the calipers (and i watched like 10 youtube videos)
i just uncrew the fluid line, at which point it will start dripping slowly, screw it into new caliper, and de-air via opening valve and pumping pedal, correct?
or do you actually clamp the fluid line off in addition?
is there any torque for the bleed valve, or just 'snug' ?
Your method will work, need two people though. Open bleeder, have someone press brake pedal EZ to the floor, and then you close the bleeder before they let off the pedal, repeat until your master brake reservoir gets to the low side, refill with fresh brake fluid. If your brakes have not been bled in a long time then repeat the bleed process on the other 3 corners, etc.
Yes, the bleeder is a hand snug, nothing crazy there. There is a torque spec for it (8ft-lb), but hand snug works. After all the work is done, start it, pump brakes a few times to seat the pads, then re-check fluid reservoir.
Hint: when the line comes out of the caliper put the end into a ziplock bag fast so the end of the line is in the bottom of the bag, rubberband it tight, etc. If some fluid pools in the bag it will cover end of the fitting so air will not run up in the line. Install it "fast", bleed the caliper.
1) are you in a high RH area, 50%+. WA is usually high RH?
2) how many times have you pulled fresh fluid down to the caliper?
