How soft/rough is the ride comfort comparing to the GX470??
On the 1st gen GX, there's adjustable suspension that you can adjust the ride comfort. I really like this. For a firmer ride, you can adjust it to sport mode. I see the GX460 has KDSS. I know ride comfort is subjective. If you ever had the GX470 with the adjustable ride, what's your thought on the ride feel when comparing the 2 rigs on normal street driving? Is the GX460(the non-luxury model) ride feel the same as the GX470's sport mode? Thanks.
Sorry but these questions drive me insane ... "comfort" ... Huh-What as you stated ... all subjective. The GX is a truck based platform ... so will NEVER ... no matter Luxury or Premium be an RX or whatever. I have had both the GX470 Luxury and GX460 Premium ... the former AVS for me was an overly complex solution looking for a problem ... no setting made any meaningful difference, with shock replacement being highway robbery in terms of cost for what it represents. The Premium has either Tokico or KYB shocks ... with very different dynamics ... so be aware that "Premium" is not all the same.
GX460 suspension can be adjusted to ‘comfort’ & ‘sport’ as well. I happen to have a 2022 GX460 and had a 2005 GX470. Ride is similar to each other. GX460 has KDSS while my 2005 GX470 was not a sport trim so did not have KDSS. I would say GX460 corners a lot better than GX470, which is attributable to KDSS. Other than that, I would say there are not much difference in ride.
GX460 is made of cheaper stuff, the cheap engine cover, without the body cladding, less wood interior, cheaper seats etc.. if not because of rust issue that makes servicing the old truck more difficult I would’ve not given up the GX470. But GX460 did not sacrifice ride quality and it has the timing chain, one less maintenance to do.
Thanks for the input guys!
@jzzfzz, Good to hear ride quality is similar.
Just curious. The 460 Premium and Luxury version has a more low profile tire(265/55 R19) that match the 19" rim. Do you guys feel any difference in the ride with this tire comparing to the standard 18" wheel tire(265/60R18) on the non-Premium 460 model?
The following 3 users liked this post by ASE:
My choice would be 17" tires, but that's not a factory option. So I swapped some on and pulled the stock wheels off.
Do yourself a huge favor and negotiate 18" wheels versus the 19" abomination ... limited tire selection in that size and more expensive. Why Lexus foisted this (current) non-standard size on their customers is a complete mystery. If one wants huge rims ... then go 20" which is an established mainstream size. Traveling distance and need a replacement ? ... good luck finding a 19" tire let alone the same brand and specific size (width / aspect ratio) within 1,000 miles for replacement if necessary.
I will have to think this over some more. The features and 19" rim style is what I like on the Premium sports package.
Contrary to the "taller sidewall = comfort" logic ... I have found that higher quality shocks perform better with a less "buffered" input from the road surface ... meaning that a softer tire / taller sidewall does not always translate to an improved ride. Shocks and Tires work in concert ... with the Lexus shocks IMHO being abysmal at best compared to higher quality alternatives.
