Idle speed rises every 45 seconds, then drops
6th Gear
I cleaned the MAS, the throttle body and waited 100 miles. The RPMs still go from 650 to 900 every 40 seconds for 10 seconds, then drop back down. Has an associated hum from the engine. Happens at stop lights and just idling in park in the driveway. Not a big deal, just might be a symptom of something else. Any ideas?
A Vacuum Leak after the MAS ... use a water spray bottle filled with water ... and (stream) spray around any junctions while the engine is running ... if there is a vacuum leak, the engine will immediately stumble and stall.
Try to turn off AC and check behavior
Different engine loads in idle can change rpm
Issue clearly happened after MAF maintenance. What changed ? That is the question that needs to be investigated ... not A/C cycling. Slow and consistent RPM cycling points to a minor vacuum leak downstream from the MAF ...
I was going to say vacuum leak, based on experience with other vehicles, in that case it was the intake manifold gasket. But it could be a lot of things.
Doesn't a vacuum leak that causes erratic idle trigger a CEL?
Got it, not sure if it was similar issue that lead to the MAF cleaning/maintenance
My point exactly ... unmetered air entering the system downstream from the MAS sensor ... so the closed-loop system is attempting to reconcile via adjustment to the air-fuel ratio ... hence the "RPM Hunting" ...
"...waited 100 miles and the idle still fluctuates." Based on my understanding he had no problems before the cleaning was performed.
Wen quality gas is used and air filter is replaced regularly cleaning the TB or the MAF is completely unnecessary in my opinion. I have vehicle with 170k miles and while visually checked the TB for excessive deposits it was not once cleaned. it has no issues of any kind.
Have you ever cleaned your MAF? Are you saying there is no possibility of an air intake leak caused by doing the MAF cleaning? Please enlighten me with your "logic", Mr. Spock.
Super Moderator
FSM and Hunting Idle
NewB2Lexus (03-18-23)
