Front turn light housing jiggle or move slightly
2nd gear
Recently I wash my GX by myself for the first time. When I clean up the front turn light on the driver side, I noticed that it seems like to be loose. I can press and move the turn light housing up and down a little bit. The other side(passenger side) seems to be tight, or very little movement. Consider the car relatively new( a few months), is this the typical quality I got from Lexus or Toyota, or some common problem on the GX460 turn light housing?
I think this is just a GX thing - both of the turn signals on my 2014 do this too.
brutus27 (08-02-23)
brutus27 (08-02-23)
brutus27 (08-02-23)
Same with my 22.
They all do this. I dampened mine by removing both and adding some foam around the outer edge and reinserting them. I think it's in my owners log....
https://www.clublexus.com/forums/gx-...ssistance.html
2nd gear
I think their engineer are just lazy to fix these small things. It wouldn't drop anyway, just feel cheap.
Thanks. Maybe just using the insulation foam can and inject them from gap on the front will also work. I just tighten the 10mm screw a little bit, looks better than it used to be now. Still move but seems okay.
