Electrical Malfunctions -Triggered by parking brake? (VIDEO)
I'm hoping someone, perhaps a lexus tech, has seen this before or has a solution. My 2014 GX has left us stranded a few times where we come back to the car after parking it and we cannot get into it with key fobs or even the vallet key like it's on some extreme lockdown mode or just electrically malfunctioning. When we get a locksmith to use a slim jim to open the door. Then the car typically starts. I've finally narrowed it down to occuring if I use the parking brake. That makes me think it's a short. However, I don't know where to start looking or if that's even the right avenue. Any ideas?
Here's the video of the malfunctioning behavior that corresponds to the "I'm going to lock you out" mode.
Super Moderator
So when this happens the use of the mechanical valet key won’t work as if the lock actuator is fighting you to not allow unlocking via the key cylinder?
as I type this, it happened again so I’m about to have to call the locksmith twice in one day. The last two times we haven’t pressed the parking brake. If it’s a short, it’s pretty easily activated- oddly just appearing when the car is unattended though….
Super Moderator
You should be able to physically open the door with the key unless lock cylinder is messed up. There are components that tie into lock and security but with a dead battery you should be able to unlock the door with that key.
Super Moderator
Potentially a circuit energized when in locked/secured state is one shorting
Do you have OBD Fusion/Link or Techstream setup to pull codes?
Super Moderator
IIRC... vehicle will try to lock the door if alarm is going off so you might be fighting that.
Did your valet key work to open the door?
Simple $20 OBD scanner won't work... need some of the more advanced models... probably approaching $100 or more, Techstream or what I use
https://www.clublexus.com/forums/gx-...stic-tool.html
I just tested the valet key. The car wasn't malfunctioning meaning the fab worked to lock and unlock. Even still. the valet key alone didn't unlock the door. Same thing if I locked the car and removed the battery neutral. No workie. I flooded the lock with WD40 and worked it around for 10 minutes on and off to no avail. Is this a separate issue?
I have a with the Car Scanner App.
I ran the diagnostic check which I supposed send any code since the last reset (not sure on that). There was a lot of "no communication" I don't know if that's a code or that the app doesn't communicate. However, it does seem to have no issues reading the coding settings or sensor readings. Question: Should I reset this and see what comes back?
Here is the readout:Car Scanner ELM OBD2
Version: 1.101.4/1.101.4/iOS
DTC report
Connection profile: Lexus OBD-II / EOBD + CANDate: 11/21/2023 8:33:24 PM
VIN: JTJBM7FX1E5077249
OBD-II
No DTC found.
Engine control unit #1
No DTC found.
ABS control unit #2ABS control unit #2
DTCs: 5
U0073 [0xC073]
Control module - data bus Off
Status: Confirmed
U0114 [0xC114]
Data bus, four wheel drive clutch control module - no communication
Status: Confirmed
U0123 [0xC123]
Data bus, yaw rate sensor module - no communication
Status: Confirmed
U0124 [0xC124]
Data bus, lateral acceleration sensor module - no communication
Status: Confirmed
U0126 [0xC126]
Data bus, steering position sensor control module - no communication
Status: Confirmed
SRS/Airbag #1
No DTC found.
Power steeringPower steering
DTCs: 5
U0073 [0xC073]
Status: Confirmed
U0114 [0xC114]
Status: Confirmed
U0123 [0xC123]
Status: Confirmed
U0124 [0xC124]
Status: Confirmed
U0126 [0xC126]
Status: Confirmed
Telematics
No DTC found.
Starter electronics
No DTC found.
Dashboard/Instrument cluster #1
No DTC found.
Climate/Heater
No DTC found.
Multimedia/Navigation
No DTC found.
Adaptive suspensionAdaptive suspension
DTCs: 3
U0122 [0xC122]
Data bus, vehicle dynamics control module - no communication
Status: Confirmed
U0124 [0xC124]
Status: Confirmed
U0126 [0xC126]
Status: Confirmed
BCM #1/Convenience systemsBCM #1/Convenience systems
DTCs: 8
U0100 [0xC100]
Data bus, engine control module (ECM) A - no communication
Status: Confirmed
U0101 [0xC101]
Data bus, transmission control module (TCM) - no communication
Status: Confirmed
U0151 [0xC151]
Data bus, supplementary restraint system (SRS) control module - no communication
Status: Confirmed
U0155 [0xC155]
Data bus, instrumentation control module - no communication
Status: Confirmed
U0163 [0xC163]
Data bus, navigation control module - no communication
Status: Confirmed
U0164 [0xC164]
Data bus, AC control module - no communication
Status: Confirmed
U0327 [0xC327]
Software incompatibility - alarm system control module
Status: Confirmed
U1133 [0xD133]
Status: Confirmed
Blind spot monitorBlind spot monitor
DTCs: 3
U0126 [0xC126]
Status: Confirmed
U0142 [0xC142]
Data bus, body control module (BCM) B - no communication
Status: Confirmed
U0129 [0xC129]
Data bus, brake system control module - no communication
Status: Confirmed
Blind spot monitor (slave)Blind spot monitor (slave)
DTCs: 3
U0126 [0xC126]
Status: Confirmed
U0142 [0xC142]
Status: Confirmed
U0129 [0xC129]
Status: Confirmed
PM1 gateway
No DTC found.
Parking sensorsParking sensors
DTCs: 3
U0100 [0xC100]
Status: Confirmed
U0101 [0xC101]
Status: Confirmed
U0155 [0xC155]
Status: Confirmed
Adaptive Front light System (AFS)Adaptive Front light System (AFS)
DTCs: 2
U0129 [0xC129]
Status: Confirmed
U0142 [0xC142]
Status: Confirmed
Electric window/Driver door
No DTC found.
Electric window/Passenger door
No DTC found.
Electric window/Rear right door
No DTC found.
Electric window/Rear left door
No DTC found.
Right mirror
No DTC found.
Left mirror
No DTC found.
Steering column
No DTC found.
Driver seat
No DTC found.
Entry & start / Smart keyEntry & start / Smart key
DTCs: 3
U0100 [0xC100]
Status: Confirmed
U0142 [0xC142]
Status: Confirmed
U0155 [0xC155]
Status: Confirmed
Power source controlPower source control
DTCs: 1
U0100 [0xC100]
Status: Confirmed
Electric windows main switch/control
No DTC found.
TelematicsTelematics
DTCs: 1
B15EC [0x95EC]
Status: Confirmed
Driver seat switches
No DTC found.
DTC report
OBD-II
No DTC found.
No DTC found.
DTCs: 5
U0073 [0xC073]
Status: Confirmed
U0114 [0xC114]
Status: Confirmed
U0123 [0xC123]
Status: Confirmed
U0124 [0xC124]
Status: Confirmed
U0126 [0xC126]
Status: Confirmed
SRS/Airbag #1
No DTC found.
DTCs: 5
U0073 [0xC073]
Status: Confirmed
U0114 [0xC114]
Status: Confirmed
U0123 [0xC123]
Status: Confirmed
U0124 [0xC124]
Status: Confirmed
U0126 [0xC126]
Status: Confirmed
Telematics
No DTC found.
Starter electronics
No DTC found.
No DTC found.
Climate/Heater
No DTC found.
No DTC found.
DTCs: 3
U0122 [0xC122]
Status: Confirmed
U0124 [0xC124]
Status: Confirmed
U0126 [0xC126]
Status: Confirmed
DTCs: 8
U0100 [0xC100]
Status: Confirmed
U0101 [0xC101]
Status: Confirmed
U0151 [0xC151]
Status: Confirmed
U0155 [0xC155]
Status: Confirmed
U0163 [0xC163]
Status: Confirmed
U0164 [0xC164]
Status: Confirmed
U0327 [0xC327]
Status: Confirmed
U1133 [0xD133]
Status: Confirmed
DTCs: 3
U0126 [0xC126]
Status: Confirmed
U0142 [0xC142]
Status: Confirmed
U0129 [0xC129]
Status: Confirmed
DTCs: 3
U0126 [0xC126]
Status: Confirmed
U0142 [0xC142]
Status: Confirmed
U0129 [0xC129]
Status: Confirmed
PM1 gateway
No DTC found.
DTCs: 3
U0100 [0xC100]
Status: Confirmed
U0101 [0xC101]
Status: Confirmed
U0155 [0xC155]
Status: Confirmed
DTCs: 2
U0129 [0xC129]
Status: Confirmed
U0142 [0xC142]
Status: Confirmed
No DTC found.
No DTC found.
No DTC found.
No DTC found.
Right mirror
No DTC found.
Left mirror
No DTC found.
Steering column
No DTC found.
Driver seat
No DTC found.
DTCs: 3
U0100 [0xC100]
Status: Confirmed
U0142 [0xC142]
Status: Confirmed
U0155 [0xC155]
Status: Confirmed
DTCs: 1
U0100 [0xC100]
Status: Confirmed
No DTC found.
DTCs: 1
B15EC [0x95EC]
Status: Confirmed
No DTC found.
Super Moderator
It sounds like you might have a defective lock/actuator assembly that may be setting off the alarm too.
There are alarm logs one can look at but you need Techstream for that.
That is a lot of codes…. I’d start with getting that driver door lock issue addressed first
Had something similar in my 22 RX when I had a electric airpump charger in front 12v socket. Uplugged it, and no problem.
[/QUOTE]
Ok- that was the valet key issue. Thanks for pointing me in the right direction!! The cog on the end of the shaft wasn’t engaged. 10 minute fix. Now at least we can get into the car if the electrical lockdown issue happens. I certainly hope that all
my problems will disappear but if not, I’m be back in here for some more help.
Acrad (11-23-23)
ViktorG
NX - 1st Gen (2015-2021)
27
12-17-23 05:34 PM
ViktorG
UX Models (2019-present)
01-11-22 04:58 AM
purple
GX - 1st Gen (2003-2009)
05-10-20 06:44 AM
