GX 460 Rear Brakes Dragging
10th Gear
I own a 2017 GX 460 with approximately 70,000 miles on it. I purchased it used and certified from Lexus when it had 55,000 miles. Recently, the dealer conducted a service on the car and observed that all four rear brake pads had 30% life remaining, whereas all the front pads were at 90%. This struck me as unusual because they claimed to have replaced all the pads at 55,000 miles. I requested a technician to investigate the rear brakes further to identify any potential issues. They reported that everything was functioning correctly, there were no signs of binding, and the pads exhibited "normal wear". However, I am fairly confident that Lexus OEM rear brakes should last longer than 20,000 miles.
Upon closer observation, I have noticed a few things:
- Periodically, my rear brakes emit a hot smell, and the calipers feel hot to the touch after driving without engaging in hard or aggressive braking.
- I experience a slight tapping sensation on the brake pedal during gentle braking, such as at stoplights or signs. This sensation never occurs during hard braking or when under heavy load. It resembles a brief, soft ABS vibration that lasts only half a second.
DanielCr (02-03-24)
10th Gear
Thanks for the reply Skeener.
The fluid was changed at 55k. I would agree that it could be a sticky piston. However, both sides are wearing at the same rate. This is why I am led down the rabbit hole of ABS. If pistons on one side are stuck would it cause the other side to stick as well?
Very unlikely where calipers seize in pairs ... with even pad wear on both sides ...
Agree ... fluid pressure is potentially not backing-off ... or front-to-rear brake fluid pressure is not being properly regulated (proportioned) ...
On the latter ... if the front-to-rear brake fluid pressure is being regulated (proportioned) properly ... under hard braking as a test ... there will be minimal rear-end lift ... or minimal rear-end "squatting" ... meaning that the vehicle will remain close to level.
DanielCr (02-03-24)
10th Gear
Thanks ASE. I will try that this afternoon and see what happens.
Hypothetically would that be an ABS pump that regulates that front to rear brake pressure? Or would it be a sensor that is sending the wrong information?
I was actually surprised ... never-ever replaced the rear brake pads on a GX-470 ... multiple 4-Runners and an FJ Cruiser before 85,000 + miles. My 2019 GX460 rear pads were gone in 30,000 miles ... well before the 38,000 mile front brake pad replacement. Maybe Lexus has changed their rear brake pad material ...
grek30
05-16-16 09:02 PM
