2012 gx coolant dripping from hose connected to top of radiator
So i found this new drip leak and Lexus is recommending total replacement of the radiator and at the same time saying they'll keep the same hoses .
To me this looks like the hose isnt seated correctly. They want over a grand to do what seems like a hose issue.. thoughts?
I'm gathering details at the moment.
ronsatour5 (02-19-24)
The radiator typically fails in the 100,000+ mile range ... with the leakage (seepage) appearing to be from the upper hose junction ... but is actually a crack in the plastic radiator housing, or due to a compromise in the bond between the plastic tank and radiator core. When replacing the radiator ... always replace the hoses and the thermostat ... cheap insurance.
The following 2 users liked this post by ASE:
ronsatour5 (02-19-24),
texas008 (02-20-24)
Thank you for the feedback. I was not aware of radiator failures being common in Lexus. My 02 LS hasnt had a single leak in the engine bay.
However, I just found the mother thread on this radiator issue everyone is having around 100k... what a shame Lexus!! They are devolving for sure...
I guess I'll be requiring them to replace the upper/lower hoses and thermostat as well with the radiator..
Thx ASE.
Thx ASE.
Thx ASE.
Thx ASE.
Radiators with plastic end caps have become way too common. I've had to replace a couple in the past few years; Saab 9-5 and Lexus SC430. If one wants an all aluminum replacement, the appear to be available (but not cheap) https://csfrace.com/new-csf-lexus-gx...inum-radiator/
MrTorgue (02-13-24)
Knock on wood so far its only thing that broke outside of normal wear and tear maintenance.
texas008 (02-20-24)
Mine failed around 77-78K. Had a leak at the upper hose where it connects to the radiator and right below it a leak where plastic and metal core join. Replaced the radiator and both hoses. This was on a 16MY last year, so 7 year old vehicle. This might not be a mileage but an age thing.
Hoses and radiator look original. I just replaced the original thermostat with a new OEM. 250k miles...
The OEM radiator looks like it is only $250 though, that is not bad at all. This is a superseded part number though, so maybe it is a "MVP" replacement given the price?
https://parts.belllexusnorthscottsda...603.html#16400
Interesting the parts diagram shows the radiator core, seals, end tanks as an exploded view (even though they come as an assembly).
Common failure as others have stated. If it were me, Denso radiator, new OEM hoses, new OEM clamps, Aisin fan clutch, serp belt, pulley, and tensioner. You're already in there so it's easy access and you'll have peace of mind that you'll be good for a long time afterwards.
ASE (02-13-24)
Interesting. The upper hose on my GX had the constant tension clamp replaced with a worm clamp. I haven't touched it yet because there must be a reason but I don't know why someone would do that. Maybe the dripping from this location is common.
I do all my maintenance by time periods and not milage, unless its something durable, I barely drive it enough in a year to justify the 5k/6 month tire rotation.
1. I bought Denso plugs and they are made in USA (not Japan) and honestly looked like crap. The pad on the ground electrode is visibly off center and overall they look lower quality than the Japan Denso I removed.
I thought I was doing well picking OEM but I regret not choosing NGK. I honestly regret installing them but it was already apart and I didn't want to do the job twice.
2. Bought a Bando OE belt but they are not the exact same. I did more reading online and others have reported the same issue. Recommend avoiding.
3. Bought the Denso coil boot and spring set. They are not at all the same as the OEM parts. I did not used the springs, looked terrible and different design/coating. I used the boots since I had it apart, but the design is clearly different.
So, while a good source for many items I will likely buy the radiator from Toyota when the time comes.
I almost bought new KYB struts from RA but have read some info/photos online that the Toyota KYB has different damping and may be overall higher quality. KYB said they are identical but I just don't believe it.
Then I saw the fan clutch pulley has a bearing behind it! That "support structure" is actually quite expensive but I am bummed to be leaving that bearing untouched. I wish it was accessible to re-grease. The idler and tensioner do not appear to be.
I suppose the alternator also has two bearings I am not replacing at the same time as well so maybe it is ok.
I will check how the fan clutch pulley bearing feels when I have it apart.
