Tire size question
7th Gear
Hey everyone,
I know this has probably been posted tons of times but it also seems everyone has a different goal in mind. I recently bought a 2023 GX and I am looking to upgrade to some AT tires. My question is this, what is the largest size tire I can fit on a stock set up, I am willing to cut and bend the plastic wheel wells and what not. The only thing I am not 100% okay with is a body mount chop. So what is the biggest I can fit without a body mount chop? I will buy a tire carrier for the larger spare.
I will lift this rig in the future but will keep it stock height for now.
Thank you in advance for the help!
Define "Largest" ... Diameter ... Width ... Wheels Specs (Width and Offset) ... this subject has been discussed ad nauseum on this forum ... do a search ...
7th Gear
large
/lärj/
adjective
superlative adjective: largest
- 1.
of considerable or relatively great size, extent, or capacity.
I agree, do a search. To help here is a 100+ page thread on the topic https://www.clublexus.com/forums/gx-...el-thread.html
The post is stickied at the top of the forum....
Official GX Tire/Wheel Thread - ClubLexus - Lexus Forum Discussion
I created a thread about this a while ago, its all based on the stock setup since the post above this one is more of a general "every tire size / shape/ modified wheel etc..." type of thread. Should be exactly what you are looking for.
https://www.clublexus.com/forums/gx-...on-thread.html
